Here are the steps I took to activate ACC on my 2022 Defender 110 (as best I can remember)
order the cable from Amazon. Cable wait for it to come
Order the software. Software. Select the Car Owner 1-VIN
You should get an email confirming order. Check spam folder if you don’t see it
Use the help bubble on the web site to connect to Gary on WhatsApp and request temp login code
disable virus detector on your laptop I. Windows security settings
download the JET Pro Installer using the link on the orders page
unzip the folder
run the installer using windows run command. You may need to run as administrator
Copy the install key from the file in the unzipped folder
paste it into the pop up window
press install. jet pro icon should be on your desktop
add a virus detector exclusion for the jet pro exe file in window security settings
Start the jet pro software
enter the login code given by Gary. You now have 72 hours to complete the task
You should see the menus.
plug in OBD cable and plug in Ethernet to laptop
press ign button on car but don’t put foot on brake
Press connect. You should see screen like this with green circle Screenshot 1
check that the battery voltage in upper right is green. If not, disconnect and run engine for a while to charge battery
Go to CCF Brushing menu Screenshot 2
Press Read CCF
Press script list. You’ll see screen like this Screenshot 3
select 17 for ACC. You may need 18 if yours is prior to MY 2022
press OK. The script should run
press exit
Press write current data. The car will make lots of flashes and noises. Check that there are no write errors
go to Main menu
select CCF Memory
select first menu item,DADC
Select second menu item, IGM
Go to DTC menu, select read DTC, then Clear DTC
when complete, go to main menu and disconnect
unplug cable
turn off ignition
lock car for 10 minutes
Do you have a lost of all options that can be activated with Jet Pro? I have successfully activated ACC, WiFi and Dynamic mode but I wanted to also activate global opening/close and tow assist but I don't know which script I should use.
Can anyone help me out please?
Im 36 hours into my 3 day JetPro licence and I just can’t get auto park to work. I can get as far as picking the space, but the start button remains greyed out. I’m using the settings above.
So far I’ve activated ACC and Tow Assist 2, but I’m stuck on Auto Park. I’d like to get it sorted before my licence expires if anyone can help. I’ve also been using the Gap IID tool up until now, but needed the Jet Pro licence to clear the faults.
Me too on my 2021 D90 First Edition and park assist did not work. No icon on the right, option grayed out in driver assistance settings, and when icon pressed from app view, park assist icon by itself would be displayed in center of screen.
Is this what you experienced in your 2020?
This is what I got when I used the script, just the steering wheel P icon in the middle of the screen, and only accessible via the app list.
When I changed the data manually, i have it working up now, right up until it's about to start moving. I have the blue P symbol on the dash and the park symbol appears on the home screen, but it just wont start the process after it has found the space
