Any idea what this is?
Old 10-08-2021, 02:00 PM
Juancl's Avatar
Default Any idea what this is?
Found this hanging a bit on the rear right corner. Tucked it back behind the bumper cover, but curious what it is.
Old 10-08-2021, 02:02 PM
Defendit..'s Avatar
Fuel overfill hose or water..
The following 2 users liked this post by Defendit..:
GrouseK9 (10-09-2021), Juancl (10-08-2021)
Old 10-08-2021, 02:44 PM
Count Laszlo's Avatar
Ditto
Old 10-08-2021, 07:35 PM
umbertob's Avatar
Agree, but I don't think it should be hanging loose like that though.
If you watch the rear bumper removal video from PowerfulUK and scroll forward to about 19:09, you should see what looks like that hose in the background, seemingly attached to a black plastic base with some sort of metal clip:
You might be able to poke your head behind the bumper, and/or stick your hand back there and see if you are able to reconnect the hose by feel, as seen in the video.
Juancl (10-08-2021)
Old 10-08-2021, 07:55 PM
Juancl's Avatar
If you watch the rear bumper removal video from PoerfulUK and scroll forward to about 19:09, you should see what looks like that hose in the background, seemingly attached to a black plastic base with some sort of metal clip:
https://youtu.be/dhquhNBzt4M
This is great @umbertob ! Thanks! I will get under the car tomorrow and see if it got off the clip.
Old 10-09-2021, 07:32 AM
clubguy's Avatar
Look at your gas cap and see if there is a drain hole underneath of it. I believe I have a hole under mine which sort of looks like someone just jammed a pen in there to make the hole. Needless to say, water still sits there like a puddle and it doesn't drain very well.
Disco2SE
04-13-2017 06:45 PM
ZGPhoto
08-14-2013 11:13 AM
Disco S2
04-01-2013 10:26 AM
Matty37221
10-03-2011 04:26 PM
Defendoor
01-11-2009 12:21 PM
Quick Reply: Any idea what this is?
