Any idea what this is?
Old Oct 8, 2021 | 02:00 PM
Juancl's Avatar
Default Any idea what this is?
Found this hanging a bit on the rear right corner. Tucked it back behind the bumper cover, but curious what it is.
Old Oct 8, 2021 | 02:02 PM
Defendit..'s Avatar
Fuel overfill hose or water..
Old Oct 8, 2021 | 02:44 PM
Count Laszlo's Avatar
Ditto
Old Oct 8, 2021 | 07:35 PM
umbertob's Avatar
Agree, but I don't think it should be hanging loose like that though.
If you watch the rear bumper removal video from PowerfulUK and scroll forward to about 19:09, you should see what looks like that hose in the background, seemingly attached to a black plastic base with some sort of metal clip:
You might be able to poke your head behind the bumper, and/or stick your hand back there and see if you are able to reconnect the hose by feel, as seen in the video.
Old Oct 8, 2021 | 07:55 PM
Juancl's Avatar
If you watch the rear bumper removal video from PoerfulUK and scroll forward to about 19:09, you should see what looks like that hose in the background, seemingly attached to a black plastic base with some sort of metal clip:
https://youtu.be/dhquhNBzt4M
This is great @umbertob ! Thanks! I will get under the car tomorrow and see if it got off the clip.
Old Oct 9, 2021 | 07:32 AM
clubguy's Avatar
Look at your gas cap and see if there is a drain hole underneath of it. I believe I have a hole under mine which sort of looks like someone just jammed a pen in there to make the hole. Needless to say, water still sits there like a puddle and it doesn't drain very well.
Disco2SE
Apr 13, 2017 06:45 PM
ZGPhoto
Aug 14, 2013 11:13 AM
Disco S2
Apr 1, 2013 10:26 AM
Matty37221
Oct 3, 2011 04:26 PM
Defendoor
Jan 11, 2009 12:21 PM
