Battery reset
Old Feb 10, 2026 | 07:56 PM
erich_aux's Avatar
8th Gear
Originally Posted by WTFChuck
I’m not sure it’s necessary, that’s why I posted my inquiry. If you read my related post about battery replacement and the failure of my Remote Climate feature after replacement, which I have used regularly over four years, and another poster’s suggestion that the module controlling the battery may be remembering the low voltage state and not allowing my Remote Climate feature to operate, it becomes a bit clearer. My battery may need a reset to tell the module that there is a new battery installed. Certainly, a simple battery swap may be possible, and my DIY replacement threw no codes or error messages, but the fact remains that my Remote Climate feature suddenly stopped working, so the prudent thing to do when troubleshooting is to look back at what was the most recent change, or action taken just before any failure. So that is exactly what I am doing.
The only other possibility is a suspect DC to DC converter which could also be the culprit, since it activates an electric pre-warmer which may be part of the problem if the battery memory precludes it from operating. Hence the POSSIBLE need for a battery reset. Have you read about the DC to DC converter issue? Or the many posters here who own the GAP tool and have performed a battery reset after replacement? If you delve deeper into these previous posts you will get an understanding of the underlying intricacies of the electronics that control our Defenders. But I’m glad the replacement of your girlfriend’s battery did not lead to any of these issues. No two vehicles share the same issues.
Well, it’s the 4 cylinder engine so no DC-DC converter.
I’m planning on getting myself a Defender this year and was thinking of getting the GAP tool.
Old Feb 10, 2026 | 08:12 PM
BritCars's Avatar
I've swapped batteries many times on LRs and Jags over the past 10+ years. All with the BMS system and the claimed 'reset'. I've never reset it and never had any issues. It self calibrates regularly - that's how it knows your battery is weak in the first place. So - you might get a shadow effect for a couple of days after changing it. But unless the new defender has a totally different setup, it will calibrate itself
Also note that it doesn't shut down systems when the engine is running as the alternator is powering the car. It's only noticeable if you are engine off but drawing power like the stereo system, other modules etc
Would love if someone has the official story of how it really works. And how frequently it calibrates?
Old Feb 10, 2026 | 10:18 PM
WTFChuck's Avatar
Originally Posted by wcc18999
Most modern cars nowadays force battery replacements to be coded to the vehicle. I guess it is one way for them to make more money. It is annoying that you have to go to the dealer to have a battery replaced.
I’m going to visit my dealership and attempt to ‘coerce’ them to reset my battery, though I’m out of warranty and truly don’t feel like paying them. This is my third battery and when I extracted battery #2 from its cubby, found that the technician at the dealer neglected to reconnect the vent line to the replacement and left it lying across the battery. But not because they forgot to, but the one they installed was apparently not a true fit because it lacked the hole to insert the vent tube into. Battery #3 that I replaced was the correct application and the vent tube lined up perfectly with the battery vent. So that failure along with the two trips where they lost some of the engine cover grommets will hopefully cause them to reciprocate with some ‘customer service’, gratis. I won’t be holding my breath waiting for that to happen though.
Old Feb 11, 2026 | 02:13 PM
nashvegas's Avatar
You do need to register it. I could type 3 paragraphs on what it actually does but these trucks have variable output alternators that also can completely disconnect. Charging goes wonky when the battery isn’t registered as a new one and it’s still basing it on the old one.
Old Feb 11, 2026 | 06:18 PM
WTFChuck's Avatar
Thank you for that insight. Further reinforces my inclination to have it registered, so hopefully I can put the squeeze on my dealership to do it for me, or I will download the software to my Foxwell and see if that will do the trick. Last ditch option will be to pull the trigger on the GAP tool, which would be a prudent purchase in the long run.
Old Feb 12, 2026 | 07:32 AM
nashvegas's Avatar
Here’s a great test if you need convincing... (I use a radar detector with an option to display voltage. This is how I monitor voltage. You could also use an OBD2 port monitor of some sort).
Baseline
  • With your “dying battery” go drive on the highway. You’ll see 14.xx volts as the car is charging it. Maybe 14.8, ish. The point here is that your marginal battery is being charged at the upper end of the variable alternator’s capacity.
Then
  • Swap in a new battery. Don’t register it. Before driving, charge that new battery overnight on a tender so you’re sure it’s topped up (not uncommon for new batteries to not be fully charged...)
  • Go on same drive.
  • It will be generally the same voltage, 14.8 or whatever. Ie -- High -- your variable alternator is full output.
Then
  • Again top up the battery overnight to make sure this is apples to apples.
  • Now register the battery with Gaptool or whatever
  • Go on the same drive.
  • After awhile - if not immediately on highway - L663 will disconnect the alternator. You’ll see 12.1, 12.5 or so. It’s not charging the battery anymore. Because you’ve told the car it has a new full battery, it doesn’t need to charge it. Which technically is an emissions saving thing, less drag on the motor, a very small (but fleet-meaningful) mpg increase.
Old Feb 12, 2026 | 11:38 AM
D-Fens's Avatar
It may end up being an unpopular suggestion, but I didn't want to spend on the GAP tool because I'm never sure how much longer I'll have the Defender, so when I needed something for my battery swap I got the iCarsoft ("LR V4.0"). It seems to have done a fine job and is cheaper than the GAP tool. Sure, you can't upload custom firmware but for maintenance things I think it's a good option. As a bonus, you get the option to download the software for two other makes with purchase, so when changing vehicles it won't be a total waste.
Old Feb 12, 2026 | 09:35 PM
WTFChuck's Avatar
I’ll look into the iCarsoft, I really don’t need all of the other coding capabilities, just a few basic ones. Battery registration, oil reminder reset, service mode, brake flush w/ABS activation would be the main items I need to control.
Old Feb 24, 2026 | 03:31 PM
WTFChuck's Avatar
Update: Just visited my dealership to request that they ‘register’ my new battery, which I replaced at my expense, third in just over four years. I informed the service advisor that when I went to replace the battery they installed under warranty and failed 18 months later, I discovered that the technician did not replace the battery vent tube but left it draped across the top of the battery. Very disappointing workmanship, combined with the two trips back to the dealer to replace the missing engine cover grommets after their service. I suggested that in the pursuit of customer satisfaction they perform this at no charge to me. I have an appointment for next week, NO CHARGE.
462disco
Sep 22, 2025 12:15 AM
ciocopoco
LR4
Aug 4, 2025 11:14 PM
CU_Roving
LR4
Aug 12, 2021 10:36 AM
ljdiscovery
Apr 18, 2019 04:26 PM
rewillia
LR4
Nov 22, 2018 05:18 PM
