I typically cartop a sailboat. I’ve got the OEM roof rack but am finding it to be too narrow and a bit bulky for my taste, the two bars are also awfully close together.
I previously used Yakima crossbars and a landing pad setup on my L322 which was awesome. Yakima doesn’t have a landing pad listed on their site for the L663 (odd since it’s now many years into the model). I’ve seen a video online with someone using a Landing Pad that seems to work but welcome any other thoughts on whether they’ve tried it, other options etc.
I have a lot of Yakima equipment, and would prefer not to have to purchase an all-new set-up, if possible.
I use the Yakima HD bars with the Landing Pad system on my factory rails. They work great and I can remove/install them in less than five minutes. Unfortunately Yakima doesn’t make a setup for the Defender mounting. I had to fabricate the mounts for the pads myself.
Hope this helps.
I use a”Thule Goal Post Rooftop Carrier” to get a longer area for ladders. It might work for what you’re trying to do.In addition to the carrier you will need a toe hitch extender to get past the spare tire.
Hope this helps.
really nice do you recall which Landing Pad set you used? How’s the load and how strong does it feel?
I was able to use Landing Pad #5 with my Jetstream bars. You'll need to use the "D" sized plates (larger plates) with the "C" length bolts (shorter bolts).
Many thanks. What distance/spread did you use between each crossbar? I'm only going to use two, and 36" seems like a safe bet. The boat I'll cartop is about 140 lbs, and I also use ties in the front and back of the vehicle to limit any lift.
I think that'll depend on your specific use case. I have my bar distance set up to work with a Yakima Skybox 16.
