Cluster panel problem
Old Jan 13, 2025 | 01:32 AM
John J Photographer's Avatar
4th Gear
Default Cluster panel problem
Hi there,
I need help with my cluster main panel. At night I can hardly see the instrument speedo or the tachometer. Very dark. I tried to adjust the brightness nothing is working . Any one knows the setting for this. I also have the HUD (HEADS UP DISPLAY ) option I have it set to the highest brightness however only stays max brightness does not dim.
let me know thanks
john
Old Jan 19, 2025 | 10:44 PM
super50's Avatar
Did you try factory reset setting?
Old Jan 20, 2025 | 08:08 AM
CincyRovers's Avatar
This has been a problem with the Defender since the beginning, and they haven't addressed it. Mine gets dim at times at dusk or dawn, but never dark enough to where its impossible to see, but its still very annoying. JLR has to be aware of this by now, but still haven't fixed it.
Old Jan 20, 2025 | 08:28 AM
lrFFM's Avatar
Did you try to adjust it manually? Mine works just fine.
pepeysol
LR2
Jul 21, 2024 09:34 AM
mzeee
Feb 10, 2023 09:05 AM
AndrewMN
Apr 22, 2022 12:05 AM
Uss
Defender
Aug 17, 2017 07:58 AM
deb1
May 28, 2017 10:04 PM
