Coolant Leak - 2022 110 P300
Old May 29, 2024 | 08:11 PM
  #21
manu's Avatar
I had the same issue on my 2021 110 s p300 after 2 years and 25000km.
Exact same radiator and leak placement! Must be a production or assembly defect.
I took it in after multiple coolant top ups. LR fixed it under warranty in 2 days.
Old May 29, 2024 | 10:03 PM
  #22
zac431's Avatar
If you are outside warranty, it is easy to replace the aux radiator yourself. See thread linked below. I got an aftermarket radiator for $85. OEM is known to leak, so why bother spending $300. I've done about 500 miles since the repair and no issues.
https://landroverforums.com/forum/20...cement-121895/
Old Jan 23, 2025 | 07:53 PM
  #23
MakintheCut's Avatar
Default Coolent leak
[QUOTE=GCSceeks on my 2022 110 P300 S (currently at 37,000 miles). I wash my 110 a lot and never noticed any coolant on the ground or under the hood. I had it in for a oil change and asked them to do a pressure test, they said "no leaks or loss of pressure." They did add a coolant UV dye and didn't see it leaking (green fluid in the pictures below the dye is UV light reactive). I suspect they didn't check the aux radiator. However, the aux radiator is only used when the vehicle get hot and the aux coolant pump is activated,
[spoiler]I did a 3,700 mile trip from FL to NY and back to NY and the coolant smell was strong especially from the driver's side when I arrived home. I think because of the heat in FL (over 90 every da
i had tge same problem
Old Jan 23, 2025 | 10:44 PM
  #24
CincyRovers's Avatar
[QUOTE=MakintheCut;921558]
Originally Posted by GCSceeks on my 2022 110 P300 S (currently at 37,000 miles). I wash my 110 a lot and never noticed any coolant on the ground or under the hood. I had it in for a oil change and asked them to do a pressure test, they said "no leaks or loss of pressure." They did add a coolant UV dye and didn't see it leaking (green fluid in the pictures below the dye is UV light reactive). I suspect they didn't check the aux radiator. However, the aux radiator is only used when the vehicle get hot and the aux coolant pump is activated,
[spoiler
most likely it is the auxiliary radiator. I had my driver’s side aux radiator on my 2021MY P300 replaced last week right before my factory warranty expired today, and my car never had a puddle of coolant under it, nor could I find the leak, but it always smelled like coolant. Turns out the leak in the aux radiator was so tiny, and it was caused by a rock presumably kicked up by a semi truck. My dealer said there were hundreds of tiny rocks in my aux radiator. Since the replacement, I no longer have any coolant smell. I’m at 39k miles.
Old Sep 15, 2025 | 09:18 PM
  #25
McFeisty's Avatar
5th Gear
Originally Posted by GavinC
Jees!
"Pop the hood and fill up the tube with the coolant sign
Couldn't be simpler. It's not rocket surgery. "........Anonymous Puget Sound Dealership circa 2022
=-) haha!
nashvegas
Oct 12, 2022 11:38 PM
Husker
Nov 4, 2019 07:42 PM
CUpgt
Apr 26, 2013 07:17 PM
tom_meeks@yahoo.com
Aug 14, 2008 05:40 PM
bigugly82
Feb 22, 2008 08:17 AM
