defender 2021 110 cup holder rubber deformed.
just tried this with a small pair of pliers, no dice I'll have to hunt down something smaller. I forgot there was a little ridge/seam along the middle of the bump. a wide headed pair of tweezers might be a good investment. also fyi, gorilla tape doesn't stick to the rubber well enough, even tried poking a small nail thru a piece so I could pull from the center.
Lots of simple ways to skin this cat.
A fish hook would also work.
Tweezers leaves no hole so is preferable.
Laugh away but… $102k for this gorgeous beast, still under warranty and 5 other cars in the driveway falling apart to deal with? Absolutely gets added to the dealer list at the next trip… and the dealer should have immediately addressed it with zero pushback. That’s my point. The dealer should do it.. not the non-mechanical owner. The fact that the original poster took it to the dealer for this means that he or she couldn’t figure out an easy pop out. So they’re prob not rebuilding transmissions on their D1 on the weekend like others here…
The same issue happened on my ‘21 110. A small water bottle caused the issue. I pulled it out with a pair of needle nose pliers but the rubber must have stretched wrong because the second I put another bottle in it deformed again. I just leave it as it is now; short of replacing the rubber insert there doesn't seem to be a permanent fix.
drk63
Dec 7, 2022 10:28 PM
wvroverguy
Jul 25, 2022 11:18 PM
