Does 2024 D90 P300 fit 18 inch wheels?
I bought one yesterday and looking to replace the stock 19” wheels so I can run Nokian Hakkapeliitta LT3 in the winter and BFG KO2/KOA3 late spring to early fall in Colorado.
I understand from @Zondar that the U.S. P300 has 13.7" front and 12.8" rear rotors but not sure if that fits most 18” wheels.
Thanks!
Thanks!
They will fit. Assuming you have the smaller brakes and two-pot calipers, you'll be fine. I think some P300s come with the larger brakes if you have 20" or 22" wheels, then you'll need to either swap or grind the rear calipers to fit 18" wheels.
The P300 and ROW D200/D250 comes with the 13.7" front and 12.8" rear rotors on 18" and 19" wheels. 20" and 22" wheels come with the 14.9" front and 14.4" rear rotors. The P400 and ROW D300/D350 comes with 14.2" front and 13.8" rear rotors for the 19" wheels (smallest you can spec), while the 20" and 22" wheels come with the 14.9" front and 14.4" rear brakes respectively.
This is false. Read this thread: https://landroverforums.com/forum/20...39/#post912816
boxerboy2
Aug 19, 2012 11:24 PM
