Domestic Plug Amp Rating
Old Mar 4, 2021 | 08:27 AM
Landy718's Avatar
Default Domestic Plug Amp Rating
Anyone know the amp rating for the optional outlet in the rear cargo area? I'm looking at getting a Viair compressor and swapping out the battery clamps for a standard socket...to avoid the hassle of opening up the hood or the battery compartment.
Thanks.
Old Mar 4, 2021 | 10:30 AM
expatbrit's Avatar
Thanks.
Someone on another forum quoted 180W. No idea where they got that from.
Old Mar 4, 2021 | 12:18 PM
Landy718's Avatar
Ah darn, if that's indeed the case, then running a mid level compressor isn't going to work. That outlet can only handle a 15A draw and the compressor I have my eyes on draws 28A maks (eks key not working )
Old Mar 4, 2021 | 07:58 PM
umbertob's Avatar
I don't understand what you are trying to do. You basically want to power a 12V DC compressor by plugging it into a 120V AC outlet? That's not gonna work, regardless of amperage or what you replace the battery clamps with. I am no electrician, but DC and AC currents don't mix and something is bound to fry without a converter / inverter.
Old Mar 4, 2021 | 08:25 PM
Landy718's Avatar
Yeah its AC to DC. There's a fair amount to deal with, but the biggest deciding factor in the Amperage allowance at that plug and all the cabling behind it.
I'm looking for the convenience of connecting a decent compressor into the outlet without have to hardwire.
Old Mar 4, 2021 | 09:10 PM
umbertob's Avatar
It's your call, but it takes maybe 30 seconds to pop the hood open and connect the alligator clamps of a good 12V compressor (I have a Viair 400P, it's great) to the + and - remote battery terminals under there. It's even easier on the Defender than my previous Land Rovers, where in addition to lifting the hood you also needed to remove a plastic battery cover to get to those terminals.
Old Mar 5, 2021 | 11:54 AM
ADVAW8S's Avatar
This....I did it just the other day to top off wife's car
landy_ala
Nov 19, 2023 12:14 PM
Jamie2333
Jul 29, 2018 06:42 PM
tsalley
Mar 2, 2013 12:02 PM
theRange
Sep 7, 2007 03:55 PM
