Factory air compressor install
Old Jun 14, 2023 | 11:57 AM
Rover1stedition's Avatar
3rd Gear
Default Factory air compressor install
Hello all. Watched PowerfulUKs video on the factory air compressor installation. Am I correct in that they actually cut the trim panel? Some form of riviting a strip joining the two sections? Has anyone done a install of the compressor with the 3rd row AC in the way? This would be a 7 seat 110.
Old Jun 14, 2023 | 12:17 PM
gts944's Avatar
AC box is immediately in front of the air compressor. Didn’t install myself but mine has failed twice under warranty. It was either port or dealer installed option where I had to pay for the install on top of the option cost. Would recommend looking into Lucky8’s ARB compressor that fits under the hood - cheaper and looked like a 30 min no skill install.
Old Jun 14, 2023 | 12:31 PM
3rd Gear
Well noted. Sadly or maybe happy I have the factory air compressor. Hopefully it wil not fail. It is a crazy amount of interior panel removal fraught with peril. Most of the trim clips that hod these panels on or one time use. I will not cut a panel because it difficult. If it when in it can come apart. Keep you posted.
Old Jun 14, 2023 | 02:27 PM
DonMitsu's Avatar
I installed it myself and have the 3rd row with rear AC. It took longer than anticipated and it does require cutting and drilling the trim panel. I have used it extensively and haven't had it fail me yet. The installation was more than I bargained for and took me most of the day on a Saturday.
Old Jun 14, 2023 | 02:35 PM
3rd Gear
I assume when you say cutting and drilling you mean for the holes mounting. Not cutting the actual trim panel in two. You removed it in one piece correct?
Old Jun 14, 2023 | 06:42 PM
drcoop's Avatar
Here’s my original thread about your exact question…
https://landroverforums.com/forum/20...limate-109597/
Old Jun 14, 2023 | 10:06 PM
nashvegas's Avatar
This exactly is my experience...
I also installed on a 7 seater 110 w/ rear AC and it took me a whole day. Was more complicated than anticipated to install but the trim holes are simple. (I don't remember riveting anything btw). Also I love it when I'm airing up and down.
Ericlockheed
Dec 19, 2022 08:58 AM
zacharyz28
Dec 29, 2021 09:46 PM
sayvillerx
May 7, 2021 06:40 AM
PurpleRain
Aug 23, 2020 12:32 PM
05TurboS2K
Aug 7, 2019 07:47 PM
