Fog Lamps — tinted
Fog Lamps — tinted
Has anyone ordered and used these foglamps found on eBay?
eBay foglamps
They appear to simply be a yellow tinted lens of the stock lamps, which is great, as I like running yellow lights off-road, but I’m not confident in their actual output.
eBay foglamps
The following 4 users liked this post by lightning:
Get Lamin-X tinted protective film. I did all of my OEM lights and off-road lights with it. I did yellow for the fogs. Plus if you don't like to color it comes right off. Was easy to install, clean surface, spray it with water, place film, cut excess tabs off (they help with install), use a hairdryer and supplied squeegee to smooth out the film. I did my headlight, fog light, all of my Off-Road lights (ditch lights, driving lights, light bar, & rear lights). Should help with rock chips as well. They also make other protection films for the Defender. I have a large strip for my OEM Ladder so I don't scratch the paint when I climb the ladder.
Fogs:
https://lamin-x.com/land-rover-defen...ht-covers.html
Fogs:
The following 3 users liked this post by GCSchmidt:
Fogs:
Fogs:
I used Lucky8’s method of running wires in the cabin (link below).
https://cdn.shopify.com/s/files/1/2178/4267/files/LK8_Def2_Roof_Wiring_Install_2021.pdf?v=1630502139
Switch Panel
Switch-Pros SP9100 8 Switch Panel
https://store.switchpros.com/sp9100-switch-panel-power-system/
Saltek SP9100 Installation Brackets
https://saltekmotorsports.com/product/new-defender-p300-arb-twin-compressor-mount/
Rigid Industries:
x1: SR-Series Pro 20” Spot/Drive - Mounted on Bullbar
https://www.rigidindustries.com/sr-series-pro-20-spot-drive-combo-921314.html
Stedi Vice Bull Bar Clamps 60mm
https://www.stedi.com.au/vice-bull-bar-tube-clamps-r.html
x2: D-Series Pro Specter Driving - Mounted on AU Bullbar
https://www.rigidindustries.com/d-series-pro-specter-driving-surface-mount-black-2-lights-502313.html
Stedi Hex Bullbar Bracket 60mm
https://www.stedi.com.au/hex-bull-bar-tube-mounting-brackets.html
x2: D-SS Pro Flood - Mounted on the hood for Ditch Lights
https://www.rigidindustries.com/d-ss-pro-flood-pair-black-262113.html
Saltek Ditch Light Brackets
https://saltekmotorsports.com/product/ditch-light-brackets/
x2: SR- Series SAE Fog Lights - Mounted near factory fog lights w/yellow lens covers
https://www.rigidindustries.com/sr-m-series-sae-fog-light-pair-902533.html
KC Hilites:
x2: Cyclone V2 Flood - Under Hood Light
https://www.kchilites.com/cyclone-led-2-light-universal-under-hood-lighting-kit-kc-355.html
x2: C-Series C2 Flood Light - Rear/Reverse Lights
https://www.kchilites.com/2-c-series-c2-led-backup-flood-light-system-519.html?queryID=d789616dae990f3797ea38dbf211682c& objectID=65&indexName=PROD_default_products
x8: Cyclone V2 Flood Light - Rock Lights
https://www.kchilites.com/cyclone-2-led-rock-light-kit-universal-6-pc.html?attr_pim_lenscolor=5730
https://www.kchilites.com/cyclone-v2-addon-kit-clear.html?attr_pim_psize=6128
Under hood lights:
KC under hood light kit with a bracket I modified to hold the switch that utilizes the radiator shroud clip for retention.
Under hood lights:
I secured the lights with large Stainless Steel fender washers and bolts with nylon locking nuts. I did have to poke holes in the liner to attach the lights…basically sandwiched the liner in between two fender washers.
I ran the wires under the hood liner (secured with heat resistant ducking tape) to the battery terminal under the hood, grounded at a factory underhood location.
Lights:
Switch bracket I modified:
https://a.co/d/9LSEQVk
ARB Dual Compressor with an external air coupling:
It is wired to the Switch-Pros SP9100 switch panel. Also, I added a ground bus bar to the Switch-Pros under hood bracket for future accessory installations.
I used the ARB Remote Hose Coupling Kit attached to a Jeep bracket (had to drill out the hole to match the quick connect coupling) to the ditch light bracket using a 1.5 meter ARB stainless braded reinforced hose connected the the ARB quick connect coupling from the ARB remote hose coupling kit.
Mounting Bracket for the compressor:
Ditch Light Bracket:
Switch-Pros SP9100 Mounting Bracket:
https://saltekmotorsports.com/product/switch-pros-sp9100-mounting-brackets-2/
Bracket to attach the air chuck to the ditch light bracket:
https://a.co/d/7kzFW3R
1.5m long ARB Braided Stainless Hose I used:
https://trailrecon.com/arb-hose-reinforced-jic-04--15m-740204.html
My Auxiliary Lighting Setup:
Switch Panel
Rigid Industries:
KC Hilites:
Under hood lights:
Under hood lights:
Lights:
Switch Panel
Rigid Industries:
KC Hilites:
Under hood lights:
Under hood lights:
Lights:
GCSchmidt (09-26-2023)
The following 2 users liked this post by chuyn:
chpsk8 (09-28-2023),
IBarelyKnowEr (12-19-2023)
