Four way amber fogs - good stuff!
I replaced my factory fogs with an Amazon aftermarket pair of lamps with much wider - especially to the sides - pattern and very bright!
This pix is just before dark.
They replace the OG fogs with a bit of cutting, and one ACC connection. I will take better pix, but here's the look. If you have an S or base, this blacks out the two fog surrounds.
Here are two better shots, though still not dark.
I will grab a couple heading down the mountain shortly.
Product.link:
T T-ABC Fog Lights for Land Rover Defender
Here are two taken just at dark:
fogs only looking at and away.
Product.link:
I prefer yellow fog lights too, especially in blizzard conditions. I've got the yellow Laminex film on our Defender fog lights.
However, on our Defenders, if the headlights are on and you activate a turn signal, the single fog light on that side also lights up. Guess it is designed to light the direction you are headed. This feature looks more normal with a white light and a little odd with a single yellow light.
Are these yellow Amazon fog lights wired separately or do they light up individually when turning like the OEM fog lights?
PaulLR (06-05-2024)
