Four way amber fogs - good stuff!
Old Jun 3, 2024 | 04:38 PM
Ratledge's Avatar
Default Four way amber fogs - good stuff!
I replaced my factory fogs with an Amazon aftermarket pair of lamps with much wider - especially to the sides - pattern and very bright!
This pix is just before dark.
They replace the OG fogs with a bit of cutting, and one ACC connection. I will take better pix, but here's the look. If you have an S or base, this blacks out the two fog surrounds.
Here are two better shots, though still not dark.
I will grab a couple heading down the mountain shortly.
Product.link:
T T-ABC Fog Lights for Land Rover Defender
Amazon Amazon
Here are two taken just at dark:
fogs only looking at and away.
Old Jun 4, 2024 | 09:02 AM
starbai's Avatar
Thanks for posting pics of this! I have been looking at em' and hesitant to pull the trigger. Was this 100% plug and play or did you have to wire up anything separately (power from battery etc)?
Old Jun 4, 2024 | 01:04 PM
wcc18999's Avatar
Can you please post the Amazon link? Thanks.
Old Jun 4, 2024 | 01:10 PM
starbai's Avatar
He did, its here: Product.link:
Amazon Amazon
Amazon Amazon
Old Jun 4, 2024 | 03:56 PM
wcc18999's Avatar
Amazon Amazon
Thanks for the link. How was the installation process? Is it pretty much plug and play?
Old Jun 4, 2024 | 04:21 PM
PaulLR's Avatar
I prefer yellow fog lights too, especially in blizzard conditions. I've got the yellow Laminex film on our Defender fog lights.
However, on our Defenders, if the headlights are on and you activate a turn signal, the single fog light on that side also lights up. Guess it is designed to light the direction you are headed. This feature looks more normal with a white light and a little odd with a single yellow light.
Are these yellow Amazon fog lights wired separately or do they light up individually when turning like the OEM fog lights?
Old Jun 4, 2024 | 07:02 PM
Ratledge's Avatar
Basically a very little trimming inside after removing the OEM fogs (or blanks) along with a single ACC connection.
You can code around that (acting as "cornering ligjts") and I have them coded to operate independent of the headlights so both fogs and brights can be on. It takes a few seconds with the GAP iiD tool.
Old Jun 6, 2024 | 07:50 AM
Ratledge's Avatar
After having them for a few days, they are so much brighter you can drive at night without the headlights. Wouldn't do it on the motorway, obviously.
The gang of three was sitting just below my house early this afternoon.
MFESQIDAHO
Sep 28, 2023 02:55 AM
Mark1107
Dec 6, 2021 04:48 PM
1979rover
Jan 4, 2019 01:34 PM
Zonk872
Jan 18, 2013 06:35 PM
hollis
May 26, 2009 10:09 PM
