Fuse number for ignition live
Old Aug 5, 2025 | 06:09 PM
Prasant's Avatar
5th Gear
Default Fuse number for ignition live
Hi, I am trying to complete the installation of CKMA12 ARB compressor in the engine bay. Everything is done and compressor is tested to be working fine. One last issue is to get the ignition live from the fuse box for the relay. I am not getting it from the fuse box correctly. In box A in engine compartment, i tried f8 (winch) and f9 (rear washer jet). f8 has no power at all. I dont have winch installed but i thought it should still have the power. f9 has power but it has no impact on rear jet. i removed the fuse and still the jet works. so i am not sure if this is configured correctly. and i dont want to connect to something important. just need to know what am i doing wrong. any help is appreciated.
Old Aug 6, 2025 | 09:37 AM
Prasant's Avatar
5th Gear
I figured it out. I had to go and test every "not important" fuses and box B f4 was unused but it still had voltage which was ignition live. So i tapped that. Just in case if it helps someone.
Grabo
Apr 25, 2025 10:13 AM
Gonow
Oct 23, 2021 02:20 AM
robdis96
Mar 26, 2016 10:15 PM
Beaulim
Sep 26, 2015 09:27 AM
cipher982
May 20, 2011 09:54 PM
