GAP IID Tool Summary
Old Apr 3, 2024 | 08:05 AM
  #191
benrh's Avatar
EUCD-129 Terrain Response Fitment
Current: With Auto Terrain Response
New: Auto Terrain Response Dynamic & Configurable Dynamic Mode
^^^ on the above I am pretty sure I could have left this as With Auto Terrain Response. When I first tried it didn't work, which is why I changed it again to Auto Terrain Response Dynamic & Configurable Dynamic Mode. I think the below is the one that was needed:
MultiCAN-696 ATCM Auto TR Mode Switch
Current: Auto Terrain Response Mode selection switch not fitted
New: Auto Terrain Response Mode selection switch fitted
Old Apr 3, 2024 | 08:24 AM
  #192
BraveSirRobin's Avatar
[QUOTE=GavinC;895044]
/QUOTE]
Apropos to the Auto-Terrain discussion... I see the comfort mode indicator in your dash display. Did you select it or is it your default mode but displaying as if a selected mode? Curious.
Old Apr 3, 2024 | 09:35 AM
  #193
GavinC's Avatar
[QUOTE=BraveSirRobin;895071]
Originally Posted by GavinC
/QUOTE]
Comfort mode is always the default unless Auto is chosen AFAIK. Auto is the only mode that must be selected via the touchscreen in PIVI. This is the way it comes from factory. I almost never use Auto. ATPC and HDC I do use. Big fan of both. Configurable TR also useful at times. All these with the exception of standard HDC, are part of TR2 activation listed in post 1.
Old Apr 3, 2024 | 09:39 AM
  #194
Jamborick's Avatar
My 24 110X came with the base stereo. I am looking to install the additional factory speakers for the surround system. Can this tool reconfigure PIVI accordingly?
Old Apr 3, 2024 | 10:39 AM
  #195
[QUOTE=GavinC;895081]
The first fully loaded 2020 L663 I sampled defaulted to Auto and one went back to auto via long press on Terrain button as mine did after I made the edits above. I am not capable of leaving well enough alone so I have been toggling settings today. My vehicle has reverted to comfort default (even with the same settings as before). Interesting🤷‍♂️
Old Apr 3, 2024 | 06:34 PM
  #196
Defendit..'s Avatar
First start to isolate the doors seriously, then add some good atermarket 2 Ohm speakers...
Old Apr 3, 2024 | 07:59 PM
  #197
benrh's Avatar
Two questions…
1) I have the Comfort and Convenience Pack, so adjustable ambient lighting. There are many different modes/options in the tool but when I try and change to one, it never works. There is a 30 color option and it displays in settings properly but the colors don’t change. Anyone had luck with those?
2) I also have the Air Suspension Pack. I show Active Roll Control as not fitted. I know the air suspension pack should do something like roll control, so wondering if it’s worth changing this one to show as fitted?
Old Apr 3, 2024 | 09:06 PM
  #198
Old Apr 4, 2024 | 10:06 AM
  #199
GavinC's Avatar
[QUOTE=BraveSirRobin;895133]
Very cool. I thought I had winkled out all the dash controls. Thanks for the info. Confirmed yesterday also, Auto mode does indeed remain as the default mode if selected.
Old Apr 4, 2024 | 10:20 AM
  #200
[QUOTE=GavinC;895162]
I seem to have broken mine fiddling about... it now defaults to comfy regardless of whether I was in auto. I was sure I had put it all back the way it was but clearly didn't... at this point I would need the CCF from a vehicle that came with TR2. Interesting that GAP has MultiiCAN 778 settings where share button and selection via rotary are either/or where I know of at least one L663 where AUTO is selectable both ways🤔
