GAP Tool G4 and Parking Assist
Old Apr 12, 2024 | 03:37 PM
  #21
chpsk8's Avatar
Originally Posted by verrilli
I’m in the USA. I didn’t use G4 though, I used the other one from Korea.
Do you know the specific CCF changes that you made? I'm not familiar with that programmer. I'm curious if it's a read/write scenario like mentioned above, or if they modified a different CCF file.
Also curious if it seems unsafe when using it? Most feedback is that the vehicle moves too quickly and doesn't feel safe to do around other vehicles.
Old Apr 15, 2024 | 06:45 PM
  #22
verrilli's Avatar
I followed the below settings from aquascape over on the defender2.net forum. https://www.defender2.net/forum/topic90062-75.html using the autosvs JET Pro tool
The perpendicular and parallel park worked without errors.
Possible park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
Old Apr 16, 2024 | 12:27 AM
  #23
GavinC's Avatar
A couple of PIVI resets and the icon appears.
As with ACC you’ll need to turn off the car and let it fully go dark to clear the Emergency Brake assist not available error.
2 PIVI resets and voila.
now I just need to try it out and see what it can do.
Old Apr 19, 2024 | 06:49 PM
  #24
GavinC's Avatar
it works just fine. Tried it out a few times today.
Old Apr 22, 2024 | 08:07 PM
  #25
nashvegas's Avatar
Tried it today on my 2020 w the new G4, using what Gavin posted up above.
Not working yet but I get the icon in the app screen - but not on right of Pivi screen yet.
Reset Pivi 2x, locked car and making dinner.
Only error I received was “start/stop switch fault detected” which did go away after faults cleared.
Showed up in Apps list
When I press the button in the apps list, I just see this.
Old Apr 22, 2024 | 09:54 PM
  #26
GavinC's Avatar
That's all I had at first too the night I installed it. Next day it was ll up and running.
Old Apr 23, 2024 | 01:15 PM
  #27
zhihong.james's Avatar
it was what happened when i activated the park assist on my 2023.5 110x with the G4 tool.
however, i was never be able to press on the damn "start" button after selecting a parking spot.
Old Apr 23, 2024 | 01:48 PM
  #28
GavinC's Avatar
Need foot on the brake to select start. Probably you already were doing that. So disregard if so. Just thought I'd mention it.
Old Apr 23, 2024 | 01:57 PM
  #29
My foot was on the brake since the car was at stop when I selected the parking spot on the touch screen. I even tried to left my foot up and press on the brake pedal again.
unfortunately, the "start" button never light up.
Old Aug 8, 2024 | 06:24 AM
  #30
Dennuske's Avatar
Originally Posted by Johan6504@gmail.com
Fallowed the steps above and it worked just fine on my Defender P400e MY22.
But I find it extremely scary and braking is harch, not sure if I will be brave enough to use it when I really need it…
I have it activated, finds spots, but i just can't select "Start".... also on a p400e
