Gas mileage
Old Jan 5, 2025 | 09:32 AM
jamesembry's Avatar
Default Gas mileage
What kind of real world gas mileage are people seeing with the 110 and 22" wheels, I6?
Old Jan 5, 2025 | 09:54 AM
Banz311's Avatar
2025 p400 here. 20-23 mpg highway; 16 around town city. Riding on 22's (285), expedition rack, ladder and box
Old Jan 5, 2025 | 10:44 AM
POPTOPP's Avatar
P400 110 gets 19-20 mixed hwy/town, 12 mpg towing. I run E-rated tires on 18" wheels so folks with a stock setup should get better fuel economy.
Old Jan 5, 2025 | 07:10 PM
RGSIII's Avatar
4th Gear
What size trailer are you towing and how good are you at following the speed limits?
Old Jan 5, 2025 | 08:14 PM
POPTOPP's Avatar
I tow a 25' Airstream which comes in at about 6,700 lbs. On the interstate, I generally cruise at 63 mph. My Defender is also a bit heavier than stock as I've added sliders and underbody armor. I've been known to get off road, way off road.
Old Jan 5, 2025 | 08:28 PM
RGSIII's Avatar
4th Gear
Thanks. That is really not bad mileage if you have added weight to the vehicle and towing a pretty big trailer. Did you add a brake controller?
Old Jan 5, 2025 | 09:11 PM
POPTOPP's Avatar
You have to. I installed the RedArc controller described in several threads in this forum. And even though JLR says not to use a weight distribution system, I do. While the air suspension will level out the truck without a WD system, the axel weights as measured at a CAT scale prove the truck was unbalanced. Using a WD system restored the front to back weights to be the same hitched or unhitched which in turn yields better steering response.
Old Jan 5, 2025 | 11:57 PM
super50's Avatar
I have a 110 with 22s, running 285s, getting 14 mpg
However I drive in the mountains, have a V8 and a lead foot.
Old Jan 6, 2025 | 08:34 AM
Xtabi's Avatar
2025 P400 22” and getting 20mpg 50/50 hwy/city driving.
Old Jan 11, 2025 | 03:50 PM
EigerCT's Avatar
2023.5 P400 22” wheels… I get 22-23 on the highway, 16-18 in town.
LR3 Bros
Mar 2, 2022 07:18 AM
alpineclimber
Jun 25, 2009 05:59 AM
LEON
Sep 5, 2007 04:25 PM
Landzu
Aug 15, 2007 01:59 PM
fanatic516
Aug 8, 2007 08:21 PM
