Is the integrated air compressor worth the cost?
Did anyone order the onboard air compressor?
Most of the time I don't bother airing-down my LR4 tires when driving on the beach. But sometimes if I park on an uphill incline, when I attempt to leave the LR4 will sink into the soft sand rather than move forward which means I do need to air down. Then I take the 10 minute drive home on 20 psi tires and use my big air compressor to inflate the tires. Onboard air would be nice, but I have a few concerns:
- What is the run time? Enough to inflate all 4 tires? I have tried some small portable compressors and they either timeout when overheating or actually melt.
- How much space do you lose in the rear cargo area? It's already smaller than my LR4 cargo area.
Thank you in advance for your feedback.
Hmmm...deflate too. That is enough reason to order it. Funny, with my Defender build at $87K, I was tempted by the new SQ7 at $90K. I just couldn't get past it having regular tires (not run flats) and no spare tire. So instead of a can of fix-a-flat, with the Defender I'll have a full size spare and an onboard compressor.
Tucker Woods (10-04-2020)
The following 3 users liked this post by avartanian:
It has fitting instructions and a part #, so I assume the air integrated compressor can be ordered and installed afterwards - it doesn't look that daunting of an install either for a DIYer.
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
Apxlvr (10-19-2020)
Yes it can be fitted after you take delivery. Mine was by the dealer. I also saw someone in a new defender facebook group install his himself.
