"Land assist not available" and no power steering on 2023 Defender 130 First Edition
Old 01-26-2024, 04:17 PM
Defendher's Avatar
How is something like this still a problem in a 24? 3 model years is a long time for this to still be a problem.
The dealer says it will fix the issue, but I have my doubts.
  #22
Old 02-19-2024, 02:47 PM
apaglione's Avatar
Same thing happened to me today. No power steering at all. I disabled the battery, waited 10 minutes and reset the battery. At startup all was fine.
  #23
Old 02-19-2024, 03:37 PM
TeddyG's Avatar
Has anyone had it on P300? It might be MHEV related glitch....
  #24
Old 02-19-2024, 04:08 PM
apaglione's Avatar
I have a 2024 X SE 110. Only 3,500 miles. I also had the issue where the front speakers stopped working (twice). I am starting to get nervous about the electronics.
  #25
Old 03-24-2024, 12:19 AM
Raylimchesing's Avatar
HI Paul.. i cannot find a 10mm terminal bolt,, can you help please, i have this same problem steering locked, with lane assistance not avaiable.
  #26
Old 03-24-2024, 06:55 AM
JBelt01's Avatar
10mm wrench to disconnect a lead to the battery which will reset the computer.
  #27
Old 03-24-2024, 07:19 AM
PaulLR's Avatar
Are you looking at the battery under the passenger seat? The top of the battery has a negative terminal marked with a minus symbol "-" and a positive terminal marked with a plus "+" symbol. There is a silver clamp attached to each terminal and this clamp is tightened with a small bolt. Loosen the bolt on the negative terminal clamp and pull the wire and clamp up to disconnect it for a few minutes. Someone posted that their battery terminals have 8mm bolts, so you may need an 8mm or 10mm wrench or any small adjustable wrench will work.
The following 3 users liked this post by PaulLR:
Charlie G (04-19-2024), Ratledge (04-30-2024), WAFOX (04-28-2024)
  #28
Old 04-28-2024, 06:48 PM
Mike_F's Avatar
Well, I’m stumped. 2023 110S with P300.
I lost power steering as I was pulling into the driveway this evening. Fortunately, I had seen this thread and ordered the 10mm insulated wrench.
Unfortunately, 10 minutes of a disconnected negative terminal did not fix the problem.
I rebooted my pivi, but no joy.
I’m on 4.1.1_ installed on 22 January 2024. Is that the latest? Of course there’s no way to force an update. I have good home WiFi when I’m in the driveway, so that’s not an issue.
Hoping it resets overnight. Or I’ll try the battery trick for a longer time period. I’d rather not lose the time it will take to have it towed to the dealer.
  #29
Old 04-28-2024, 07:26 PM
TeddyG's Avatar
I hope there are enough reports to initiate some sort of recall. Loss of power steering is not a small deal.
  #30
Old 04-28-2024, 08:04 PM
Mike_F's Avatar
Just left the battery disconnected for an hour. No change. I’ll call the dealer in the morning.
Quick Reply: "Land assist not available" and no power steering on 2023 Defender 130 First Edition
