Missing bolt on front under shield
Old Jun 4, 2024 | 10:49 AM
Chris_P's Avatar
I know this is an old thread but I too have a missing bolt 'E' from my 2022 110 P300 S TReK edition. After dropping the under armor last week to change the oil, I noticed that there is a welded on nut missing from the under shield moputing bracket/brace 'A" in the images abave. So that explains why I am missing a bolt 'E' as there is nothing to thread into.
Anyone else have this same issue?
Chris_P
'22 Defender 110 'TReK Edition' 18/70
Old Jun 4, 2024 | 03:02 PM
SilverSFR's Avatar
Here are some black ones from BRITCAR. You might need to weld or tack a nut to the bracket for easy access.
M10 x 25 torq pan bolt
Old Oct 27, 2024 | 02:47 PM
Chris_P's Avatar
While cleaning up and removing copious amounts of mud from behind the front skid/bash plate, my remaining pan torx bolt came loose. Upon further inspection the other weld nut fell off the support frame. I will need to remove the support brace in order to weld in weld nuts better than factory (hopefully)
2022 Defender 110 Bash/skid plate mounting hardware weld nut failure
Mulley
Sep 5, 2021 07:50 AM
Paul1987
Jul 8, 2021 06:58 PM
Noah Woodcock
May 11, 2017 07:11 AM
adolfojbonilla
May 2, 2016 11:31 AM
Darover
Nov 5, 2008 02:36 PM
