Mounting Accessories on OEM Expedition Roof Rack (e.g Matrax, shovel, etc)
Has anyone figured out the best way to mount Maxtrax on the expedition roof rack either flat or on the side without any custom fabrication? Are there off-the-shelf mounts/t-bolts/accessories that works?
In general, for those of you who has the roof rack, how are you mounting things on it?
worked with the accessories that work with the Thule wingbar . The expedition has insert t-bolt openings. Btw save the rubber inserts in the rail it helps eliminate wind noise
![](https://cimg3.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/d7d27ad7_5c80_4edb_9251_deee69fd4d07_d9bbcbdab7d76032969f268d876f4c3ef3aa4123.jpeg)
Craig_RRS2013 (03-31-2022)
https://www.frontrunneroutfitters.co...nting-kit.html
https://www.frontrunneroutfitters.co...eel-clamp.html
i would try this, but you would need to get T-bolts that work with the OEM rack (Thule or Rhino Rack) to fix it to the rack.
