No Lift tire size guide (work in progress)
Old Jul 7, 2021 | 10:10 AM
  #121
Barstoolman1127's Avatar
So, here's a post from back in April, with a fellow member, with virtually the same vehicle as mine. As you can see, he put 275/65/18 on his Steelies....according to him, no worries, no lift. The pics are at access height.
[img]images/icons/icon1.gif[/img]Thanks all for the input. I ended up putting on Nitto Terra Grappler G2s in 275/65R18. I liked that they are slightly lighter than some of the E rated truck tires, but still carry the XL rating. I haven’t gotten off road yet, but no noticeable noise increase compared to the Michelin tires. Plus they are snow rated. So far I’m happy with them. And no rubbing, even at access height.
Old Jul 17, 2021 | 06:59 PM
  #122
GetOutTheWay's Avatar
Default Aftermarket wheels/tires for 2021 P400 D90..?
Hello boys,
I am having a time trying to find the right aftermarket wheel and off road tire for my 2021 P400 D90 First Ed. I want more rubber and less wheel on the ground as I have some rather nasty roads to travel 8 months a year. The 20" OEM wheel "sticks out too much" and is doomed to abrasions....18's don't fit on my model, I tried one anyhow since other models listed 18's, 19's....(I tried a JNC wheel at 18x9 with a 35 offset, No go. Wouldn't fit over the brake/hub and a suspension part in the way tooo)) Anybody tried a 19" wheel? I'm grinding my teeth
Old Jul 17, 2021 | 09:46 PM
  #123
NoGaBiker's Avatar
D400s have bigger brakes than D300s, hence the unavailability of 18s. However, 19s are optional on D400s — I don’t know if every 19” wheel in the world would fit, but the OEM 19s are free options on D400 so you should be in good shape there.
Finding much choice in rubber in 19”, however, is a different story. I’m used to 17” wheels on my Jeep, and in fact, I actually used 16s for my big 37” bias ply offroad tires, so I wanted lots of rubber and less wheel, just like you. 18s would be great because the Wrangler Sahara JK, of which hundreds of thousands were sold, came with 18s so there is a nice selection of 18” rubber for offroading (though not as good as 17.) But since they won’t fit, I checked out 19, figuring even that 1 extra inch would help, and there just aren’t any tire choices.
Old Jul 18, 2021 | 05:39 PM
  #124
Default My P400 wheel problem for "more tire,less wheel"
I uh had a dumb moment. I was only looking at my rear wheel....I see now why there is no way to downsize a wheel on a 2021 Defender 90 p400. This (I haven't yet looked to see just what this suspension part is, I will here asap) is in the way and I can't imagine offsets to clear this little dandy, as it's inside the wheel. So...20's and not much tire to play with unless a lift . Ehhh
Old Jul 18, 2021 | 06:00 PM
  #125
Yes, there is no way to fit 18's, 19's on a P400 D90. I posted a photo of my front tires and wheel. There is a suspension part right inside the wheel itself, so only 20" and above will work. There is just about zero tires sizes to play with and as yet, I don't know much about Land Rover lifts. I have air suspension ....So, that's why I'm here to see what hacks are coming around. I just want more tire and less wheel for the off roading. I didn't buy a Land Rover to just drive to the outlet malls. I may be kicking myself for selling my go anywhere FJ Cruiser. All that $'s sitting in the D90...ehhh. Thanks for your input!
Old Jul 18, 2021 | 06:22 PM
  #126
GavinC's Avatar
Originally Posted by GetOutTheWay
Yes, there is no way to fit 18's, ...on a P400 D90. Thanks for your input!
There is this way
or
This way if you want to choose different 18" wheels
Old Jul 18, 2021 | 06:51 PM
  #127
umbertob's Avatar
You can safely remove that hockey puck thingie, it's a single screw holding it (I assume some sort of harmonic damper) in place. My 110 P400 came with 19" factory wheels and that chunk of metal wasn't installed upon delivery. Removing it will allow you to fit 19" factory wheels all around. 18" wheels won't fit, but the issue will be the rear calipers, not the fronts.
Old Jul 19, 2021 | 02:03 AM
  #128
Originally Posted by umbertob
You can safely remove that hockey puck thingie, it's a single screw holding it (I assume some sort of harmonic dampener) in place. My 110 P400 came with 19" factory wheels and that chunk of metal wasn't installed upon delivery. Removing it will allow you to fit 19" factory wheels all around. 18" wheels won't fit, but the issue will be the rear calipers, not the fronts.
Seriously? I can remove that "apparatus"? And then put on 19's? Now I will really have to crawl under and grub about if that might work. I just want to make sure that it's not part of my air suspension is all! (I really don't like the stock wheels personally, as they are a bit boring and "stick out too much" which will rub on rocks and etc.) I'am a good driver, but you know, I can just see airing down the current tires even just a bit ....and suddenly...you are left with nothing more than a cantaloupe rind for tires. Thank you for the info. I'll be checking how to do, checking back on this thread too for ideas. I still need to look at what offsets for aftermarket wheels. The OEM +41 is a strange number. I like a couple +35's offsets....I'm sure some thread here will help with that. Again, TY for the info
Old Jul 19, 2021 | 10:54 AM
  #129
spikemd's Avatar
You can swap out rear calipers for Disco5 rear calipers and fit 18s. The rears are the factor, not the fronts.
I bought the 4cylinder to fit my 18 inch steelies and MT tires. I powdercoated them black.
Old Jul 19, 2021 | 06:13 PM
  #130
After looking into the lack of tire options for 19" wheels/tires, I think I will have to look at 20's and see what I can do or maybe with a rod lift as another member suggested may work. In the aftermarket world 5x120 is Lux car wheels, and few off road. Thank you for the info!
