No Lift tire size guide (work in progress)
Old Sep 16, 2021 | 08:08 PM
  #191
Bikman's Avatar
I am not sure if their kit has original LR calipers and their current solution is for the 18 inch rims. I believe they are selling a complete kits with wheels. I did fair research into this and finally laid it. If you buy the P400 with 22 inch wheels. you dont need to change the rear calper. All you need to buy is the rotar, rotor housing and the pads and use the same caliper. You can buy the Rover sport rotor, pads and housing for the rear wheel. Make sure the front brakes are bled, and dont need to do anything to rear brakes. If you want to do complete the front and rear, you are looking around $7k USD. This will give you original LR brakes and Tuffant 18 inchwheels and Falken AT tires. This is what cost my friend who did his complete make over recently. Also I would not recommend doing the lift rods. X lifters is coming up with their electronic lift kit. I believe it will be released early 2022. Its much better solution then rods. The kit will be around $700 USD.
Old Sep 16, 2021 | 08:10 PM
  #192
Bikman's Avatar
They have a good solution, not sure if they are using LR or knock off.
Old Sep 17, 2021 | 01:13 AM
  #193
GavinC's Avatar
Information on the LR part numbers used
This is information from someone who installed these calipers and Tuffant Alloys.
Old Sep 17, 2021 | 03:57 AM
  #194
_Allegedly's Avatar
"We have an OEM caliper conversion for your Defender 2..."
LR102243 + LR102246 $370 for the set. That's a big difference if it's really what they are using.
Old Sep 17, 2021 | 06:44 AM
  #195
NoGaBiker's Avatar
If your calipers are not colour painted, you do not need to replace them to put 18 inch rims. However you will need to change the rear rotors, brake pads and housing for the rotors. but you can you the same caliper. You can buy the Range rover rear brake kit without the calipers and install 18 inch wheels. also you willneed to bleed the front brakes, not the rear brakes. The best person to talk to is Jake at Tuffant USA. He is great guy and very helpful.
I think you’ve gotten this all backwards.
I don’t believe there’s any situation where you need to replace rotors (but I’m not sure about what comes on trucks with 22s.) But on trucks with 20s you need to replace the rear calipers with the L8 calipers, which use the same pistons and pads as the existing LR OEM rear calipers. The rotors (discs) don’t need replaced.
The caliper is the red thing, the rotor (disc) is the silver thing.
Cheers!
Old Sep 17, 2021 | 07:27 AM
  #196
_Allegedly's Avatar
Cheers!
I'm not sure either but some trims are getting 15" (380mm) rotors. I'm pretty sure that's the front of the V8.
From Lucky 8:
Then I stumble across this from Land Rover:
No coffee yet so I'm not even trying to wrap my head around a wtf 20" disc rn. Can't be.
Old Sep 17, 2021 | 07:56 AM
  #197
Bikman's Avatar
P400 with 22 inch factory wheels come with 380mm (F) and 365mm (R), but use the same standard silver calipers in the rear. No need to change the calipers if you want to go down to 18 inch. however, you will need to the the Disc, disc housing and pads. No mods to the front tire.
V8 comes with performance brakes (blue calipers) regardless of the wheel size. still 380mm (F) and 365mm (R), but you need to change the everyting to go down to 18 inch.
Old Sep 17, 2021 | 08:06 AM
  #198
_Allegedly's Avatar
I'm finding that hard to believe and a little big if true.
Shaved/slim calipers don't concern me as long as they are still structurally sound. Stopping power would be the same.
Smaller discs and pads though, not good for stops, driving in heavy traffic, or torque vectoring.
Old Sep 17, 2021 | 08:25 AM
  #199
GavinC's Avatar
Their package deal price is pretty good for 5 Tuffant Alloys and these calipers. The forum member who shared the part numbers has them installed as planned.
Old Sep 17, 2021 | 08:58 AM
  #200
_Allegedly's Avatar
I really don't want to like these as much as I do because they're 20's.
https://www.chelseatruckcompany.com/products/land-rover-defender-2020-present-overland-steel-wheel
