No Lift tire size guide (work in progress)
Old Feb 4, 2024 | 08:03 AM
  #541
Chris.Gio's Avatar
Leaning towards replacing the 22’s with 20’s.
i like the Fuel Wheels D733 Warp in black. Would use KO2’s (or KO3’s if out yet). Prob 275/55?
The wheels come in an 18 offset and a 30 offset. Which do folks think I would need? Would prefer the “stock” look regarding sidewall and fender (wheel not sticking out etc)…
Old Feb 5, 2024 | 02:23 PM
  #542
AAJR's Avatar
Originally Posted by Chris.Gio
Good idea. This was done using manuf websites:
Wow, great table. I already have Mickey Thompson tires on a spare set of wheels (except 20 inch wheels) , but this table should be helpful to people who might want to use 22 inch wheels.
Old Feb 7, 2024 | 08:42 AM
  #543
cgardnerma's Avatar
Hi folks. I just picked up a 2022 Standard and drove it straight to the tire shop for some new rubber. Thanks to this thread, I went with 265-70/18 on coil springs and like many of you, I have no rubbing at all. Tires are the new Duratrac RT. Much quieter than the previous version which I had on another car. I also went with the 116T and not load range E which have identical load handling and heavier construction than the XL spec tires that came stock. Tire is 8 lbs heavier and measures 32.6 in diameter. Here's a pic:
Old Feb 10, 2024 | 08:45 PM
  #544
vicfoss2's Avatar
3rd Gear
Originally Posted by JesseRohr
Installed 275/55/20 BFG Ko2 on factory 20” wheels. Zero rubbing with or without the 30MM wheel spacers installed.
is this pic with the 30 mm spacers installed or not please??
Old Feb 13, 2024 | 11:04 AM
  #545
BraveSirRobin's Avatar
JesseRhor: did you notice much increase in tramlining with the wider tires? how close are you to your suspension?
Old Feb 13, 2024 | 11:19 PM
  #546
Chris.Gio's Avatar
After talking myself in and out of many ideas, I landed on going from 22’s to 20’s.
Next came the fun of researching what wheels I wanted. Lots of options but I was drawn to a set of Mondials from Kahn in the UK. Not sure I’ve seen them on the forum yet but Kahn and Chelsea Truck Co are worth a google.
Imported them myself with a small $150 tariff + around $600 in shipping as I recall.
Pics below using KO2’s in 275/55. If curious, these wheels are purpose built for our Defenders and come in a 30 offset.
Old Feb 14, 2024 | 04:29 AM
  #547
Ratledge's Avatar
Default 19" 255/60 Falken Wildpeak AT
Has anyone tried the slightly (1/2") smaller sidewall as a "solution" for the 19" quandary?
These are not the AT3, but the OG model.
Old Feb 14, 2024 | 07:09 PM
  #548
littlehandegan's Avatar
275/70/18 fits just fine with 1.5 rods
Old Feb 14, 2024 | 10:31 PM
  #549
POPTOPP's Avatar
That's great to hear. I wanted to move up to a true 33" tire, but thought it would require a mod to the front wheel well regardless of the height.
Old Feb 15, 2024 | 01:29 AM
  #550
Pfc8584's Avatar
Hi completely clueless about tires and wheels. I have p400 on oem 20inch wheels. Will falken wildpeak 265/50/20 or 275/60/20 fit? I'm asking because it a good price. Thank you.
