No Lift tire size guide (work in progress)
Old Aug 30, 2024 | 08:55 PM
  #641
mmcmah's Avatar
Originally Posted by rhoadesel
20" 6011, lugnuts are LR OEM black, center caps were picked up from amazon. I didnt like the silver ring on the OE center caps
Thanks. I didn't realize they were OEMs.
Does anyone here have a concrete recommendation (without having to pay as much as an OEM wheel) of a 20" wheel that will fit the brake calipers of a 22" OEM-fitted P525 V8?
Old Aug 31, 2024 | 08:35 AM
  #642
Always_Traveling's Avatar
4th Gear
Hey Guys, new here to the forum. I’ve been skimming through all the comments on tire/wheel sizes. I just purchased a ‘24 110 Carpathian Edition and thinking about changing the wheels to Vossen 20” HF-2’s with the Nitto Recon Grappler 275/55/R20’s. I would greatly appreciate any feedback on the potential in rubbing with this setup. Thanks in advance!!
Old Aug 31, 2024 | 02:25 PM
  #643
cc1999's Avatar
What is the exact size and offset of the wheel you’re looking at. 20x? +?.
Ie. My wheels are 20x9 +30 offset running the same size tire, Everything clears no issues at all.
Old Sep 1, 2024 | 07:39 AM
  #644
4th Gear
The Vossen wheels I’m looking at are 20x9 +32 offset.
Old Sep 1, 2024 | 11:17 AM
  #645
cc1999's Avatar
Ok, that’s a good spec.
Should fit perfectly, no rubbing or anything to be concerned with running that 275/55R20s.
‘That’s within 2mm of what I running, my tire choice has an actual width closer to a 285 then the 275 it shows on the sidewall.
‘My tire is 11.1” wide, 11.2 is a 285. You should be good to go with the combo you’re looking at.
Old Sep 1, 2024 | 05:35 PM
  #646
Mike_F's Avatar
I'm playing with ideas to make this a more useful guide. A thread with 645 posts in it really isn't useful anymore. We need a table we can reference quickly, and one that can be edited.
I created one on the "talk" page of the L663 Defender entry in Wikipedia.
https://en.wikipedia.org/wiki/Talk:L...re%29_Guide%3F
I have no idea if that's something the wiki editors would allow on the main L663 page, but if you put it on "talk" you're just kicking around ideas.
I added data based on my Defender (110S P300 with the stock 18" GY Adventures), and everything I could find in this thread up to the 100th post in the thread.
What do you all think? If Wiki allows it to go to the main page, is it something you would want to help update? What other data is relevant/necessary? For example, I added suspension (coils/springs) since that probably changes whether certain sizes fit (some probably fit coils, but won't fit the same vehicle with air at access height).
Do we need to add a column for spacers? Wheels (OEM vs. aftermarket)? Mudflaps?
Thanks,
Mike
Old Sep 1, 2024 | 07:07 PM
  #647
LL247's Avatar
I would add spacers, flaps, ect to any tire guide. For example, I was able to run 275/50r22 Bridgestone Alenza on my last 110, but only after removing the wheels spacers in front. My current 110 has the 255/65r19 and with the classic mudflaps, can't see going any bigger.
Old Sep 1, 2024 | 07:19 PM
  #648
Mike_F's Avatar
I added columns for Spacer (mm) and Mudflaps. What tire was your 255/65R19? Also Bridgestone Alenza? Does that come in a 19? Or did you go with Goodyear Adventure or Duratrac?
Old Sep 1, 2024 | 11:19 PM
  #649
LL247's Avatar
My 2020 110 P400 came with 275/45r22 Michelins I believe they were (don't know the tire model, they were smoked and got replaced quickly), and added 1in spacers f & r, had the small mudflaps. Swapped them out for the 275/50r22 Bridgestone Alenza, not sure exactly since they were take-offs I purchased on FB Marketplace, but they fit only rubbing when the spacers were on. Guessing it worked because the tread was very mild and the tires didn't have a large footprint or squared shoulders.
The new(er) 110 P400 I just picked up the other day has 255/65r19 Goodyear Wrangler All Terrain Adventures, and the Classic mudflaps. I added 1" lift rods and 1in spacers, it's very close and I can see a tiny bit of contact on the liner at full lock with the spacers installed.
Old Sep 2, 2024 | 05:00 PM
  #650
Mike_F's Avatar
Well, the reply from a wiki editor was "I think Wiki policy says we don't include that sort of technical detail - see Wikipedia is not a manual, guidebook, textbook, or scientific journal in the "What Wikipedia is not" policy." Not surprising. That's why I put it on the "talk" page instead of the main page. I don't see any place in this forum to build a table - I was hoping there might be something in the "tools" submenu, but no luck. Oh, well. It was worth a shot.
