No Lift tire size guide (work in progress)
Old Apr 5, 2025 | 09:11 PM
  #721
Nerdflex's Avatar
3rd Gear
I just pulled the plug and ordered 275/55/20 Cooper Discoverer Road+Trail AT tires on Black Rhino Alston +25 offset wheels. I will post pics once installed. I really hope they don't look too small, though I do think they are the best size for the space provided.
Old Apr 6, 2025 | 07:56 AM
  #722
Ratledge's Avatar
Anyone know what the order code for BFG K03 size 255/65R19 is? I found it once before, but don't know where. I believe they will be out this year, but we waited three for the K02 not to arrive.
Old Apr 7, 2025 | 08:31 AM
  #723
CincyRovers's Avatar
I asked when the 19" size will be available on the BFG website not too long ago, and this was the response:
However, the MSPN (Michelin product number) is 20879 according to the PDF. They did confirm the OEM 20" size will be available in August, so assuming the 19" is still on the table, I'd assume it'd be in August, too. Still awaiting to hear back from BFG if they did in fact decide not to make the 19" size.
Old Apr 9, 2025 | 05:54 AM
  #724
Ratledge's Avatar
However, the MSPN (Michelin product number) is 20879 ...
jeez! Go figure? Wasnt the one 19" correct size but D load rating? Pretty sure they didn't show an LT flavor. I rim light load 33/36 on my D90S.
Old Apr 9, 2025 | 03:37 PM
  #725
Per the BFG website:
Old Apr 10, 2025 | 04:25 AM
  #726
Ratledge's Avatar
I finally found a goid copy. I had that PDF before but I switched phones recently. 20879 is what I remembered. That sure makes it look like it's coming.
Old Apr 11, 2025 | 09:41 AM
  #727
more snow's Avatar
4wd High
Where did you order them from?
Old Apr 11, 2025 | 01:12 PM
  #728
If you're referencing the OEM sizes for the KO3, they aren't available yet. The 20" will be available in August, and the 19" are confirmed for sometime this year. When they will be available, you can order them from your local tire shop or places like Tire Rack or Costco etc.
Old Apr 15, 2025 | 11:29 AM
  #729
norol's Avatar
Faulken Wildpeak AT4Ws 275/55 r20 fit great with no rubbing at all in access height.
Old Apr 27, 2025 | 08:51 PM
  #730
honolulugator's Avatar
Default Will this tire fit 285/50/R20?
My new D130 400 came with 22 inch wheels. My LR4 has 20 inch with Nitto Ridge Grappler 285/50/R20, prior Johnson Rod lift, now springs with very slight rubbing. Specs are 31.26” diameter, 11.69” width. Daughter getting LR4 for street use, can I switch wheels between trucks?
No rub at standard height would be great, although I have a 1 inch lift programmed on D130.
