No Lift tire size guide (work in progress)
Old Apr 29, 2025 | 09:00 AM
  #731
CincyRovers's Avatar
Originally Posted by honolulugator
My new D130 400 came with 22 inch wheels. My LR4 has 20 inch with Nitto Ridge Grappler 285/50/R20, prior Johnson Rod lift, now springs with very slight rubbing. Specs are 31.26” diameter, 11.69” width. Daughter getting LR4 for street use, can I switch wheels between trucks?
No rub at standard height would be great, although I have a 1 inch lift programmed on D130.
You should be fine. The maximum diameter tire you can fit on a Defender without modifications is 32.6"
Old May 1, 2025 | 06:01 AM
  #732
A1C6's Avatar
Not necessarily tire size but I found this cool web chart by LR describing each tire
Im assuming the ‘off-road’ ones are the Wranglers and the ‘professional off-road’ are the Duratracs.
Old May 1, 2025 | 08:09 AM
  #733
Correct. The off-road tires are the Wrangler Adventures and the professional off-road tires are the Wrangler Duratracs.
Old May 8, 2025 | 10:26 AM
  #734
nashvegas's Avatar
I would love to make a parody version of that chart. Or really a more accurate version.
Talk about grading on a curve (grade inflation)...
Adventures score a 9 in the snow? HA.
Old May 9, 2025 | 03:29 AM
  #735
GavinC's Avatar
we have been on some trips with folks on these highway adventures.
on no occasion did the Defenders shod thusly, reach the destination.
9/10 lol
id love to know what the tire and wheel guys at LR are smoking.
“let’s give them a 19” rim with a papier-mâché tire”
Old May 9, 2025 | 07:35 AM
  #736
Ratledge's Avatar
9/10 lol
I have a MY23.5 D90 and it came with GY Adventure "AT"s. They are truly crap for the intended purpose. No Kevlar? That is the only big plus for this brand. Hoping to see BFG K03 tires in August? They have published a SKU for 255/65R19, we'll see.
Currently on 60 series OG Wildpeaks which are adequate and at least don't fly off snowy roads.
Clearly much better on typical gravel roads here in the Black Mountains and around the Smokies.
Old May 9, 2025 | 09:49 PM
  #737
Zondar's Avatar
The "off road" tires are actually very well suited for their purposes:
1) They must provide a good, safe, comfortable, quiet drive during customer's test drives.
2) They must appear more like off-road tires than passenger tires, for those who care about the looks.
For that, they are fine. They are genuinely excellent for driving on clean, smooth, dry pavement, in range of AAA, like most of their target (rich) market areas.
But off-road? Yikes, scary!!!
Old May 11, 2025 | 07:35 AM
  #738
Ratledge's Avatar
And imagine my surprise the first time I touched my brakes on 2" snow? Darned near flew off the road and I am a well seasoned mountain driver.
Of course if I was serious or dedicated vehicle you'd have to go with Duractracs at least on 19" rims, anyway.
Old May 12, 2025 | 10:16 AM
  #739
rakusak's Avatar
Originally Posted by Guapo
No lift rods. P400 with Lucky8 rear brake swap. Redbourne Alston 18” wheels. Nitto Ridge Grappler 265/70/18. Very minor rubbing only occasionally. So far so good. Tried other larger sizes but all rubbed too much. Don’t want to run lift rods. And the black lug nuts weren’t in when they did the install....so yes, I will have them in black.
pretty much the same setup I’ll have by weeks end + spacers as the rear Alston still caught the caliper in the back.
Old May 24, 2025 | 03:44 PM
  #740
foggy's Avatar
What did you specifically hate about the Adventures? Over the years I've read several negative posts about them, but I've never had a real issue. I do moderate Jeep roads in CO with them in the summer, and they only see patches of pavement for 4-5 months a year - snow. We don't really deal with mud or roots like you would in NC so maybe thtat's it???
I like them as they are acceptable for many tasks: interstate (quite), snow, moderate Jeep trails, dirt roads...
