Oil for the D MHEV
Old Apr 2, 2022 | 04:52 AM
alps.defender's Avatar
Default Oil for the D MHEV
Does anyone have a spec recommendation for the diesel mild hybrid 3.0?
Also has anyone found an oil filter part number that is on Amazon?
what is total oil capacity on the 3.0 diesel?
thanks!
Old Apr 2, 2022 | 12:49 PM
GavinC's Avatar
thanks!
Oil Type needed is Here SAE 0W-30 meeting Jaguar Land Rover specification STJLR.03.5007
9.8 L capacity of oil in the diesel 3.0 is listed Here
Oil filter on amazon is
Here Here
Fits the 3.0L Diesel and Petrol engines apparently
Old Apr 2, 2022 | 09:29 PM
GrouseK9's Avatar
@alps.defender - Study the oil a LOT. This isn't your Dad's 0W-30 (or whatever). You need to have the specific product number because there are horror stories about this. Lots of posts re: the oil, in fact if you go up to the three permanent threads one is on this topic. You should go back to the perma-thread and read thru it. Much better info up there already than regenerating here: Link. Good luck and the video is priceless!
Old Apr 3, 2022 | 12:40 AM
Oil filter on amazon is Here Fits the 3.0L Diesel and Petrol engines apparently
thanks for the links, I’ll keep digging on other websites beyond Amazon as over here in Europe that filter doesn’t show up, and the specified E version of the 0W-30 is 20 bucks a liter! If anyone has found a cheaper solution please share.
Old Apr 3, 2022 | 12:43 AM
thanks, read through that one a few times but it focuses on the petrol engine. Thought I’d start one for the diesel 3.0 folks so people don’t get confused and get the wrong oil.
Old Apr 5, 2022 | 04:23 PM
Marco225's Avatar
Hello everyone! Oil for diesel engines and filters I compare Oil Filter for Duramax Diesel Engines on this site https://southwestexpresslube.com/oil...iesel-engines/. Very useful information for car owners, especially since the advantages of one or another filter for different types of engines are indicated here.
Old Apr 14, 2022 | 12:59 PM
Default Half an oil change
Could only get out 5L with the vacuum extractor. Tried everything I could think of but that’s all I could get out. Have it all back together and topped off, not happy but I feel better than before, at 24k km…. Can’t believe the standard Land Rover service waits until 34k km before they change it…
New filter and half an oil change better than nothing I guess, but if anyone else has had trouble with the diesel via vacuum or figured out a trick please share.
Old Apr 14, 2022 | 02:05 PM
GrouseK9's Avatar
Not sure what kind of extractor you're using, but if it's the "standard" one that should hold the entire Defender oil change, then you likely don't have complete connection at one of the air couplings or didn't push the end of the hose down the dip stick far enough. Sad it didn't work for you. Hope for better success next time.
geekinc
Nov 13, 2023 04:35 AM
5Xdriver
Mar 5, 2022 05:08 AM
SoCalWiley
Dec 20, 2018 08:48 PM
ESPN
Sep 4, 2011 09:31 AM
DiscoRom
Nov 23, 2008 09:01 AM
