P300 Oil Filter Wrench
Old Sep 25, 2024 | 01:53 PM
ThunderBob's Avatar
Default P300 Oil Filter Wrench
Was is the best wrench to use to remove oil filter on the P300 (2.0 Liter engine)? I purchased the
Steelman Low Profile Oil Filter Cap Wrench Socket 65mm and 67mm x 14 Flute, 3/8-inch Drive, Heavy Duty Chrome Vanadium Steel
from Amazon and while the wrench does fit, when I insert my 3/8 inch ratchet it pushes the socket off the filter. Very frustrating.
Many thanks,
Thunderbob
Old Sep 25, 2024 | 02:42 PM
GavinC's Avatar
I use my hand. Torque on these is low. Hand loosen, hand tighten.
Old Sep 25, 2024 | 02:49 PM
chpsk8's Avatar
Don't push your socket wrench too far in. It doesn't need to go over the little ball on the wrench.
I put the oil filter tool on the filter, then push the socket wrench into the tool just far enough to make a connection, and twist it.
BTW I have a ton of these types of oil filter tools and they all do what happened to you to varying degrees.
Sdrows
Oct 20, 2022 11:09 AM
Brokenrover
Jul 21, 2010 05:27 PM
2002 freebie se
Freelander
Jan 5, 2009 04:20 PM
troubled
May 27, 2008 05:09 PM
rcendo
Dec 24, 2007 01:48 PM
