stuck oil filter
Old Dec 23, 2007 | 08:20 PM
rcendo's Avatar
7th Gear
Default stuck oil filter
any ideas on how to get a stuck oil filter off my 98 disco??!!!!
Old Dec 23, 2007 | 08:50 PM
Default RE: stuck oil filter
Sounds like you had one put on too tight.
What sort of a filter wrench do you have?
Do you have a large set of channel locks, worse case they will work.
I have seem some that had to be cut off with a hammer and chisel.
Old Dec 23, 2007 | 09:11 PM
jkid's Avatar
Take a long narrow punch (say no less than 8") and drive it through the filter with a hammer, then use the punch to turn the filter. Pretty messy, but it works great. Then go buy an oil filter wrench for next time (the type that fit over the end of the filter work great, all others are a pain in the butt.
Old Dec 24, 2007 | 11:48 AM
jmt's Avatar
jmt
I've done similar with an old screwdriver and a hammer -- on an 04 VW Jetta. It's a last resort, but it will work.
Old Dec 24, 2007 | 01:48 PM
okdiscoguy's Avatar
Just make sure and poke the screw driver/ punch through the bottom of the filter. As said before, messy, but works great. Get a K&N filter next time. They have a nut on the bottom...
HawesEA2
Dec 17, 2016 09:47 AM
powderhound
Jul 7, 2014 10:51 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
smyevich
Aug 31, 2006 01:31 PM
