K@N Oil Filter Vibrating Loose
Old Oct 18, 2022 | 07:00 PM
Sdrows's Avatar
Default K@N Oil Filter Vibrating Loose
Anyone had a problem with K@N 0il filter vibrating loose?
Not necessarily a disco only problem but they do get vibrated a lot.
I noticed a snail trail of fresh oil coming off behind my 4WD Dodge HEMI a few months ago. A big one coming off the filter. Backtracked it more than a quarter mile. Very lucky i noticed it before next restart ( Do not routinely check this ones oil before starting LOL) . Changed filter, fixed problem
Last week checked rovers oil like always before starting in the morning. Almost a qt.low. Oil puddle under oil filter. Small stream coming off while running. Tighten some but still dripped. New filter installed with no leak yet.
Hard to gauge the tightness using such a large wrench as it seems like it would be easy to over do it.
I'm just gong to check tightness more often .
Old Oct 18, 2022 | 07:33 PM
Best4x4's Avatar
Never had an issue like that with the white case HP3001's
Old Oct 19, 2022 | 04:33 PM
Sdrows's Avatar
I'm probity not torquing down enough. Worried about to much torque with the big wrench maybe.
Back in the day you did not want to tighten filter to tight.
Old Oct 19, 2022 | 05:12 PM
Harvlr's Avatar
Assuming a petrol engine like mine, I tighten 1 full turn after the gasket contacts.
Old Oct 20, 2022 | 10:50 AM
Sdrows's Avatar
OK Thanks Harvlr
I'll do that on next oil change. I wonder if there is a recommended torque on these.
Also will start checking filter after long runs down rough gravel construction roads. So much smoother at 25mph than 5mph
Old Oct 20, 2022 | 11:01 AM
redwhitekat's Avatar
could be a bad oil filter, i tighten mine by hand only,
Old Oct 20, 2022 | 11:09 AM
Sdrows's Avatar
I always have but will now turn some past hand tight. Hate to even think what a replacement HEMI cost but I KNOW what a new 4.6 cost.LOL
loganpendergraft
Nov 5, 2012 12:42 PM
Pwoens
Oct 7, 2012 09:59 AM
turtle
Dec 1, 2008 10:07 AM
troubled
May 27, 2008 05:09 PM
snugg
Apr 16, 2008 05:27 PM
