Question on GAP Tool
Old Sep 9, 2024 | 08:09 PM
Kaylorsan's Avatar
@ficklma1 I confirmed this today with the GAP Team and on my Defender
In the HEIGHT ADJUST SCREEN
- DEFAULT is the original car height settings. This button is essentially a ‘restore settings to original’
- The 3 custom buttons allow 3 options to set up an offset dimension from the Default setting.
- Once programmed/applied, the Offset would apply to all three modes in the vehicle (access, standard and off road). For example, if I want to lower my access mode by 10mm, it would also lower my standard and off road heights by 10mm
- The 3 custom buttons can each be programmed to different offsets, however the offsets for each button are applied equally across the modes. For example, there is not a way to lower access height but keep standard height as-is (on the Defender at least).
ficklma1
Aug 1, 2023 12:11 PM
Overlandx
LR4
Jan 8, 2022 08:38 AM
grantluna
May 8, 2019 11:36 AM
Soccerboi4
Nov 14, 2017 08:14 AM
