Radard detector and dash cam hardwire install
Old Sep 16, 2021 | 03:31 PM
  #21
Count Laszlo's Avatar
Here’s my update on the R7.
Went out and the fuzz was a plenty, but unfortunately the R7 was kaput.
It worked fine right/left and behind, but forward it was dead up until about 40 ft.
So I have put my R7 up for sale. I only used it when I traveled to British Columbia for ski trips and never really sped over 75, but Oregon is 65 and that’s a real drag.
Anyway, I’ll survive without one. Just need to be mindful and careful.
Old Sep 16, 2021 | 06:07 PM
  #22
Muppetry's Avatar
It should work fine mounted high in one of the clear sections without the blocking film. Is there a reason you didn't want to put it up there?
Old Sep 16, 2021 | 06:09 PM
  #23
I do see that area but can’t figure out how to mount it there because there’s no room to anchors it. Any advice how to do that is welcome. I love my R7
Old Sep 16, 2021 | 06:26 PM
  #24
Muppetry's Avatar
I have a V1 mounted there on suction cups, but I guess it depends on the mounting hardware available for that unit. It seems to be very secure and working fine, other than blocking rear laser (not important) when the sun visor is in use.
Old Sep 16, 2021 | 06:32 PM
  #25
Doh. Suction cups. I remember a set in the box. Let me try that. I’ll report back. Thank you.
Old Sep 16, 2021 | 09:21 PM
  #26
Thanks, Muppetry.
I found a small suction cup mount in the original box. It works perfectly and the detector is working locally as it always has. Will have to try highway this weekend but I’m confident it’ll work fine.
Thank you!
Old Sep 17, 2021 | 07:07 AM
  #27
clubguy's Avatar
Need wiring info. Did you wire to the fuse box behind the glove box? I'd rather get power from the mirror if possible.
Old Jan 7, 2022 | 12:48 PM
  #28
robsonj's Avatar
Thank you, followed the instructions here to add a mirror tap. V1 version1 powers on nicely, now to see if it works with the heated window etc!
Old Jan 7, 2022 | 01:07 PM
  #29
PaulLR's Avatar
I had no problem tapping into my old LR4 center dome light wiring for my V1 but there are far too many wires in the Defender mirror/camera area for my auto electronics skill level. So I took the easy way out. Used the socket in the center console, ran the V1 wire under the dash and up the left pillar. I had to take off the panel under the steering wheel and the grab handle at the far left side of the dash to run the wire. The V1 cord just reaches the area where the windshield coating is cut out.
Works great. And for anyone still using a first generation V1, get the new one. Nearly eliminates the false alarms from Honda blind spot monitoring and false laser warning from an oncoming Volvo or Infiniti. Ka range is far better too.
Old Jan 7, 2022 | 01:10 PM
  #30
robsonj's Avatar
I was gonna upgrade to a v2, unfortunately they aren't doing upgrades at the minute due to the chip shortage. Suppose I could sell the v1 v1 and then just buy the v2, extra hassle though :-)
