Rear end thump
Old Jul 22, 2024 | 12:41 PM
docsigmund's Avatar
Default Rear end thump
Have a 2021 Defender with 65k miles. Right after my first major service, I noticed periodically a thump coming from the rear and generally on the passenger side. It only happens at low speeds and generally when I turn to the left. It is more pronounced when I am going up hill and it doesn’t happen regularly. Has anyone else noticed this in their Defender?
Old Jul 23, 2024 | 05:37 AM
AVLDefender's Avatar
There is a pretty extensive thread on this in here somewhere. It is not great.
Old Jul 23, 2024 | 06:06 AM
sarek's Avatar
As stated, there are already threads on this. Long story short, rear differential is failing on models with the electronic locking rear diff.
Old Jul 23, 2024 | 07:08 AM
WTFChuck's Avatar
Why does it always seem that everything is fine, and the noises and problems seem to occur right after you get it back after service? My Defender has been flawless since I picked it up, except for the time a few months back when I had them replace the A-pillar for the noise issue, (although they only did one side, even though I informed the Service Advisor the noise was on both sides) and I was hearing a noise which turned out to be the engine cover flopping around since the ‘technician’, and I use that term loosely, was not proficient in replacing it and there was a missing rubber grommet and two others mashed out of place leaving it unsecured. I guess it’s hard finding skilled mechanics these days.
Old Jul 23, 2024 | 08:21 AM
CincyRovers's Avatar
See the attached thread:
https://landroverforums.com/forum/20...mpaign-121642/
Old Jul 23, 2024 | 01:09 PM
DefenderSISU's Avatar
Default Rear differential
Rear differential will have to be replaced. Had mine done at 61k. Full of metal I was told but they would not let me see it. As I had ask to see it so I could take pictures for the group. So we could learn from it.
Old Jul 23, 2024 | 01:35 PM
wcc18999's Avatar
It is your right to keep the parts they replace unless it was covered under warranty, where the dealer has to keep it in case LR asks for it. I am surprised that they would not at least show it to you. Strange....
Old Jul 23, 2024 | 03:36 PM
Submariner2009's Avatar
I just had my rear diff replaced under warranty for the same reason. Thumping and vibrations. Took a lot of back and forth with the dealer, approvals from LR etc. Sorry to hear you’re being hit with the same issue.
Old Jul 23, 2024 | 05:58 PM
Default Under warranty
It was under warranty so maybe that is why. But I was thinking what now if in another 60k I have the same problem? I was told it was like $7k for it. I don’t want to spend $7k on a new one in 60k miles. I would convert it to an air locking like on Sarek’s new ones. But god know how much he wants for one. Has to be 10k ? But I don’t know for sure.
drjam
Jun 21, 2024 09:39 AM
Cmw1100
Defender
May 1, 2024 01:27 AM
kiwiscott
Sep 21, 2023 11:04 AM
jusmax88
Oct 24, 2022 03:27 PM
Pangea123
Dec 9, 2021 02:24 AM
