Rear Wheel Clearance Issue
Old Nov 12, 2024 | 05:29 PM
Banz311's Avatar
Default Rear Wheel Clearance Issue
Shop is in the process of fitting 22' wheels (Vossen HFX-1) on Nitto Recon Grappler (285/45/22). I was told that the wheel set up for the rear door is impeding the wiper and sitting too flush. Found a spacer for the rear, however was only in stock in a tilt position. Wanted to see what everyone else is doing with A/T tires on bigger wheel setups. Thanks
https://newdefendermods.com/collecti...-spacer-tilter
Old Nov 12, 2024 | 07:04 PM
queezy's Avatar
I don't have it, but I noticed this option: https://lucky8llc.com/products/offse...versized-tires
Old Nov 13, 2024 | 01:03 AM
nashvegas's Avatar
I don't totally dig the look of the tilted spare extension... It looks like it's falling off or worse, like someone rammed the car from behind and bent the rear door a bit. I might hold out for the other one -- ie 'd get the one that keeps it mounted straight up and down, like that lucky 8 one.
If you look at pics of the new Octa, they have a scalloped cutout on the top of the bumper to make room for a bigger tire/wheel combo, which is kind of cool. But that part isn't available from JLR or aftermarket.
Old Nov 13, 2024 | 10:12 AM
Banz311's Avatar
thank you for this! just ordered
Old Nov 13, 2024 | 11:21 AM
Banz311's Avatar
agree with you as well, if only the bumper cutout was available for us non-Octa owners.
Old Nov 13, 2024 | 05:19 PM
Defendit..'s Avatar
Some options:
1. Just use spacer rings, enough thread left for securing the wheel.
2. Space the carrier, 1/4" no problem, some work.
Picture down here with just spacer rings
gts944
Nov 1, 2024 08:50 AM
WaltNYC
Jul 5, 2024 09:42 PM
taylorswiftgang
Oct 19, 2023 08:18 AM
jusmax88
Aug 20, 2022 08:02 PM
Springlandy
Defender
Jan 16, 2022 04:29 PM
