Remote Start Question
#21
When scrolling through my functions on PiviPro last night I noticed there is a toggle for windshield heater and another for rear defrost to start automatically. Wish I could remember where I was but if those options are turned on, then I believe the remote start activates them if the outside temp is cold enough - whatever temp that may be. I still wish the seat heaters and steering wheel would turn on as well. Maybe some later iteration?
- Heated windshield button: Press to switch on or off. If left on, the heated windshield deactivates after a timed period, dependent on the ambient temperature.Note: In cold ambient conditions, the windshield and rear screen heaters switch on automatically when the engine is started. The function can be switched on or off via climate settings.
Note: The heated windshield operates only when the engine is running.
Then find Apps> Climate> the ability to turn on the windshield and rear defrost as "turn on when engine starts" toggles are there.
Thanks for pointing me in the right direction. Now to see if I can find a CCF change for turning on the seats and steering wheel. That would be perfect if that exists.
#22
#23
#24
Thank you, thank you, thank you!! Definitely would not have found this otherwise. What a ridiculous sub menu to have this hidden under. (And yes the toggle is turned off from factory)
