Replace Spark Plugs P400 Defender
Sorry yeah. easy mistake to make W.Aus and WAshington. I've been to Townsville a couple of times. Fun place but Cairns is my first love. I used to have a little 2 door Holden Jackaroo. Never did much wheeling when I was there. Just a bit of dirt between Cairns and Cooktown. Fun little rig.
I just replaced by spark plugs on my P300 2024 110 Defender S 4 cylinder. I managed the task without removing anything significant -- just barely did I manage it.
It was a devilish job and was only possible because of a simpler overall design P300 vs. P400, very small hands, and very, very slow activity level. I have absolutely no doubt that the dealer would have removed all the items you did for your P400. That would be the only way to change the plugs reliably in an every day fashion.
By, the way, I paid to have the 2013 LR4 plugs changed by the dealer last month. Lordy, it was a LONG and expensive task -- I am so happy I turned that over to JLR. I took one look and opted out of going on that adventure.
Enjoy !
Enjoy !
Enjoy !
Enjoy !
One more reason to opt for the P300 over the P400.
What's your mileage now btw?
My next jobs will be front diff drain and fill
Transmission drain +fill x2 or x3
The former is supposedly a lifetime fill.
The latter I'd need to check in the manual.
You also have to buy a very small 16mm socket and maybe some weird extensions, but you could also go to a dealer.
Welcome to the forum
Wiper puller works great. Cheap and a a good little tool to have in the arsenal.
I had much better luck with this puller, built really well and popped both of mine off in under a minute after fighting with another for a half hour and bending it all up. This one is awesome.
https://a.co/d/c2DtYeY
Thanks for writing this up. I found it very helpful. The photos were the best part
One thing to note that short hose that you had a hard time disconnecting from the charge air cooler, has a spring like clip on the plastic 90º elbow just below it. I was able to use a flat head to pop the spring clip out allowing the charge air cooler to rotate upwards. No need to fight it off or on
I’m glad the post was of some use to you.
moonspoon
Mar 30, 2023 01:27 PM
lfoster
Oct 27, 2020 08:24 AM
Was a bit confused when you said you were in the states… until I realised that Kirkland isn’t a city in Western Australia - it’s a city in Washington
