Retrofit / Upgrade Domestic Plug Socket
Old Apr 16, 2023 | 03:11 AM
Defendit..'s Avatar
Default Retrofit / Upgrade Domestic Plug Socket
Next mod, the Domestic Plug socket - inverter is only capable till 180w. Not very useful except charging some devices.
So out with the old one and upgrade to an 12v 1500w Pure Sinus Wave inverter.
Location in my case under the loadspace in my Hardtop / Commercial.
Next power supply, this inverter can take up to 100 amps. So I had to make made new 0 awg Power cables of 4.5 ft. Direct on the Battery after the BMS.
First testing with the remote on/off - monitoring display
Testing the Nespresso Essenza Mini coffeemaker ( 1100w) on the Mudstuff table
So now I have to finish with a new Domestic Plug Socket ( Schuko in Europe) , the look will be almost like stock.
So a lot better prepared now for overlanding, or just lunch with coffee.
Will finish this week and upload the final picture.
NAS version
https://www.voltworks.cc/products/vs-1500pbr
Old Apr 16, 2023 | 02:37 PM
markjlr's Avatar
LR Forum Vendor
I added the 2nd battery and a 1000 watt inverter along with solar and the alternator charging both batteries when running. I also set up my domestic fridge freezer to run directly off the battery.
Great work.
Old Apr 19, 2023 | 01:53 AM
Defendit..'s Avatar
Default Finished
Finished this install yesterday. Side panel back and connected. Recovery gear back in place.
Flat flooring back.
Rubber lining and ARB fridge straps back in.
Old Jan 25, 2025 | 03:43 PM
longtrip68's Avatar
You guys have made some amazing mods.
Question: I am not planning on Overlanding; however, I would like to increase capacity of the domestic plug in the cargo area to allow use of a 600 watt electric tea kettle. Without going crazy; could it be as easy as swapping the OEM inverter with a larger one? Would I have to replace the outlet itself as well?
On that note: where is the OEM inverter located?
Old Jan 26, 2025 | 08:06 AM
Defendit..'s Avatar
No you can not just swap this inverter for a more powerful one.
You also can not use the outlet, needs to be replaced for a normal domestic one.
The inverter is located nearby the EAS unit, in the rear right side.
Old Jan 26, 2025 | 10:24 AM
AAJR's Avatar
NAS version
Were there pictures with this post? They seem to have disappeared?
neuropathy
Jul 17, 2021 06:29 PM
Brandon318
Jul 10, 2020 11:44 AM
nicpro
Mar 24, 2020 08:36 PM
Somerls
May 12, 2019 08:02 AM
Saturnine
Jun 13, 2018 12:26 PM
