rim size choices?
Old May 18, 2024 | 10:12 AM
curb-optional's Avatar
Default rim size choices?
Hi all: for a 2025 110 Defender using a 3.0L mild hybrid, I see a number of wheel options at the 20" rim size. Here's my question: are any of the rims designed for a wider tire? For example, the stock is a 255. If you have 4-5 20" rim choices, do all of those rims use the same 255? Or are any of them offered to accommodate a wider tire? As a followup, if I had to have a 20" rim, can I pick a rim that can fit a 275/60/20 tire, without doing any adjustments what-so-ever to the wheel arch and breaks? Thanks!
Old May 18, 2024 | 10:27 AM
GavinC's Avatar
All rims in each size have identical width and offset.
8.5” width on all 19” and 20” with a +41.5 offset.
8” on all 18” Offset is again +41.5
9” on all 22”. Offset is +39 (not sure on that last offset but it’s on the iguide) OEM is 275mm width on these tires.
Nothing in rim choice I’m any given size will affect your options for that given rim diameter.
tires in these sizes 32-42”. 8-9” width rim is no concern.
255-315mm width. No concern on these rims.
TLDR. No
Frank4
Mar 6, 2018 01:38 AM
DiscoI
Dec 13, 2013 11:38 AM
atancreti
Sep 5, 2011 08:33 AM
squid
Freelander
Jul 16, 2009 11:51 AM
STLROVER1981
Jun 27, 2007 05:52 PM
