Rodents?
Old Aug 17, 2024 | 07:38 PM
v35's Avatar
v35
Default Rodents?
Coolant light went off on my defender so I took a look under the hood. The coolant level is definitely low so looks like I’m in for one of the common coolant issues on the forums but more concerning was the pile of fluff I saw in my engine bay around the radiator lines. First thought is rodents as it doesn’t look normal. Thoughts?
Old Aug 17, 2024 | 11:49 PM
v35's Avatar
v35
Solved. Looks like they took the insulation off the engine cover and made a nest at the bottom of the engine.
Old Aug 18, 2024 | 06:50 AM
wcc18999's Avatar
Rodents have a strange way to make it through engine bays for whatever reasons. Place traps and baits around the area where you park your Defender so that you can keep rodents away from the engine bay.
Old Aug 18, 2024 | 08:45 AM
Jbiggzs's Avatar
This may be an old wives tale but buy a few bars of Irish spring soap and place them around your garage. Our Toyota mechanic gave us the idea as rodents are attracted to the type of plastic Toyota uses in their wiring looms for our camry hybrid.
Old Aug 18, 2024 | 10:29 AM
WTFChuck's Avatar
Just read up on this and another suggestion is to use some peppermint oil spray on and around the engine compartment and exposed wires. Also use bait traps and repellentsin a garage if that’s where the vehicle is parked. Some have suggested noise generators that emit a sound not detectable by human ears to keep them at bay. Good luck, they can cause considerable damage. It’s reported that they are not necessarily drawn to wires for the taste, but that they need to gnaw constantly to keep their teeth sharp and the round shape of wires is perfect for them to hold onto and wrap their teeth around as they chew.
Old Aug 18, 2024 | 12:18 PM
nashvegas's Avatar
My engine cover is also missing about 25% of its insulation - same thing and looks as if it's been chewed on the underside . Luckily I had no damage and found nothing else-- but I noticed this when I did an oil change earlier this year.
Old Aug 18, 2024 | 03:17 PM
chpsk8's Avatar
We use dryer sheets and get similar results. When we store boats over the winter we throw a few around the boat and the smell apparently keeps the mice away. The boat next to mine had a main harness chewed and he didn't use dryer sheets. He isn't laughing now.
Old Aug 18, 2024 | 05:25 PM
Elektrapops's Avatar
I started a thread a while ago when squirrels chewed thru my loom - totally dead car. Hope you can see this and maybe it can help?:
https://landroverforums.com/forum/20...er-pad-115349/
GCSchmidt
Sep 15, 2025 09:18 PM
NativeTexan
Apr 17, 2025 02:24 PM
Flamgat
Aug 22, 2023 10:42 AM
Flamgat
Aug 20, 2023 07:56 PM
nashvegas
Oct 12, 2022 11:38 PM
