Side steps that wont corrode?
Old Mar 26, 2026 | 09:52 PM
JimmyAK's Avatar
Default Side steps that wont corrode?
I purchased 110 side steps from hunters prestige 2 years ago and after 2 winters the paint has completely flaked off on both sides and looks like **** now.
Any recommendations on where to order all black 110 side steps that will last?
Old Mar 27, 2026 | 04:39 AM
sarek's Avatar
The quality of the powder finish and prep for materials especially aluminum is very important. Not too many manufacturers will do high quality finish in an attempt to lower pricing. Our aluminum products go thru an ECC process to prep for powdercoating. This is done at a facility that is similar to corrosion protection performed at auto manufacturing plants. Similar to anodizing, it creates a bond between the aluminum and the finish coating that prevvents corrosion creeping and flaking. It may chip with an impact, but will not cause corrosion to creep under the rest of the coating as with most other aluminum products. Good prep for steel and other metals is also very important. This is another case of getting what you pay for. Proper finish work is not cheap, so it tends to make the finished product more expensive.
Old Mar 28, 2026 | 11:38 AM
JimmyAK's Avatar
can you link me the ones you sell for a 110?
Old Mar 31, 2026 | 05:34 AM
sarek's Avatar
We do not sell a proprietary step only, the step is incorporated into our rock sliders. Here is a link to those
Sarek.shop
Old Apr 1, 2026 | 12:27 AM
isugoo's Avatar
Can you share pictures of current condition please?
Old Apr 1, 2026 | 01:08 PM
nashvegas's Avatar
The reality is that most of Hunters Prestige’s parts are knockoffs sourced from China remarketed as high end accessories -- so this isn’t surprising. You’d do better for durability / quality with the genuine LR side steps but you can’t offroad with those at all, as I’m sure you are aware. Certain rock sliders function very well as side steps too, as Sarek points out.
Old Apr 1, 2026 | 11:22 PM
isugoo's Avatar
Do you guys think OEM will have better quality powder coating and worth its $$?
Old Apr 3, 2026 | 01:22 PM
JimmyAK's Avatar
What about Urban? Are those side steps cheap China knockoffs as well? I don't offroad with this vehicle, so I would get the LR oem ones, but they don't offer them in all black.
Old Apr 3, 2026 | 02:40 PM
isugoo's Avatar
They offer black with silver steps and all black steps now.
OEM ones from online dealer costs 1400-1600 while knockoff version without Defender logo is 200-300 (with Defender logo version is 350-450). So it's somewhat tough to swallow.
Also on the side note, I have eBay all black OEM style without the Defender logo currently for Defender 90. But the kit came with all 4 exactly the same mounting bracket (front bracket should be longer than rear - same for both Defender 90 and 110). Installing steps with all 4 same brackets make step look too high on the front (almost touch the body) and lower on the back. So make sure to check with online vendor if you're buying non-OEM version.
AgentMir
Mar 15, 2025 10:59 PM
drgek
Aug 28, 2023 12:47 PM
Camdisco24
Mar 8, 2016 08:06 PM
bulldozer32
Sep 3, 2010 09:49 AM
DrG3
Aug 2, 2010 09:35 PM
