suspension : front down/rear up
#32
More info: “Have the service dept specifically check the front valve block assembly which controls flow to/from the front air springs. The assumption is that there would be a leak somewhere in the normally closed valve/axle cross link air path between LHS and RHS front air springs, as both front springs are deflating when parked.”
I, too, will be dropping my Defender off for service.
#33
Ran the issue to ground…. Early build 2020 Defenders have defective front air struts that require replacement ☹️ Found out today that there was a TSB for the issue, back in late 2020. That TSB was resigned and is now just in the maintenance manuals. I suppose if no one complained about the issue JLR didn’t say anything 🤷🏼♂️
#34
