Sweet Smell from Engine
Old Dec 27, 2024 | 03:55 PM
hawkeye50's Avatar
4th Gear
They all seem to do it at varying degrees...Have a 2023 Discovery, 2023 Discovery Sport and a 2022 Velar and they all tend to lose a little coolant..annoying
Old Jan 10, 2025 | 10:27 AM
CincyRovers's Avatar
I just picked up my Defender from the dealer for my final service under factory warranty. They replaced my driver's side auxiliary radiator. There was a tiny pinhole leak that was caused by a rock hitting the radiator, presumably kicked up by a semi truck. They said that the leak was so small, it would probably take months for the coolant level to significantly drop.
Old Jan 10, 2025 | 02:44 PM
Submariner2009's Avatar
The aux radiator on the drivers was replaced and had a small but visible leak. I can still smell some sweet fumes, however, so when I take it back for another small repair (part on backorder) I'm going to ask them to double-check. I've had some people say the sweet smell is common even without a leak; they did perform a pressure test etc.
Old Jan 10, 2025 | 06:25 PM
gurka01's Avatar
I am not sure about sweet smell is common. The only time you should be smelling that is if there is free coolant somewhere in the engine bay.
I have had my Defender from 2020 and when i smelled the sweet smell it was the inlet to the turbo. Took them a while to find it.
Submariner2009
Oct 26, 2024 08:13 AM
DFW_Landy
Nov 1, 2023 08:24 AM
jamestfl
May 28, 2014 09:52 AM
Disco C
Jul 11, 2010 08:51 PM
mac25dm
Jan 21, 2008 08:21 AM
