Tailgate/Tail Door hold position
Old Mar 19, 2024 | 10:33 AM
WTFChuck's Avatar
From the manual. There is no action by pressing the latch button on the handle, as suggested, which locks the door in the desired open position.
Old Mar 19, 2024 | 11:51 AM
Muppetry's Avatar
Interesting - that note describing open and hold doesn't show up in my version of the iGUIDE. I cannot remember where I read about pulling the release lever, but obviously what was happening when I did that was that I was effectively holding the door position for a second or two, triggering the hold function. Thanks for clarifying.
Old Mar 19, 2024 | 11:53 AM
longtrip68's Avatar
Yeah, I didn’t think so.
Old Mar 19, 2024 | 01:38 PM
Chris.Gio's Avatar
Open the door to the position that you want, then immediately pull it back closed a little.
On mine this locks the strut and the door stays where it is.
worked for me
Old Mar 21, 2024 | 11:56 AM
longtrip68's Avatar
This usually works for mine, but for the times that it doesn’t I simply open the door to where I want it, then cycle the door back and forth (open /closed) about 2-3 inches. Within a few seconds you can feel the “locking mechanism” engage and hold the door steady.
Old May 22, 2024 | 08:17 AM
longtrip68's Avatar
OP here. So, turns out my gas strut was bad. The only reason I realized this was that I was at Dealer and opened tailgate on a new showroom defender and noticed that the tailgate “locked” into position as soon as it was stationary - like the manual describes. I ordered a new gas strut and it was an easy install. Problem fixed.
Old May 22, 2024 | 11:45 AM
Ronin Defender's Avatar
Here's the solution I came up with when parked on a hillside...
Cut a small pice of PVC pipe , slot it so that it clips onto the rod and bingo the rear door won't slam on you ever again.
When you are ready to go just give the wire loop a tug and off ya go.
Old May 22, 2024 | 12:53 PM
Can_Glu's Avatar
how about using one of these with about the right size? it may need a bit of modification to "bite" firmly to the strut bar.
Donegal64
Dec 14, 2021 07:20 AM
EGC8758
Oct 26, 2021 03:31 PM
Novy!
Dec 12, 2019 11:20 AM
buzzybee328
LR4
Nov 4, 2017 03:47 PM
rodrick smith
Jul 18, 2007 09:37 AM
