Those with heated & cooled seats......
Old Feb 16, 2023 | 04:55 PM
  #21
X-dynamic's Avatar
Originally Posted by Low Country
Hi all,
Just for the heck of it tonight while I was driving I tried the heated and cooled seat functions to see how they felt. I expected in the cooled seat function to feel some breeze somewhere in the cushions. But what I also noticed in the heated seat function was blowing air hitting me behind my knees . There was air blowing under the bottom seat cushion towards the back of my knees/calfs regardless of whether I was using the heated seats or the cooled seats.
Can those of you with heated/cooled seats see if you feel air blowing under the bottom seat cushion towards the back of your knees?
Thanks a ton!!
Hi
I am having the same issue with my 2023 LR Defender, were you able to find out what the problem was.
My dealer told me it was normal.
Thank you
Old Feb 18, 2023 | 01:13 AM
  #22
this_account_is_mt's Avatar
On vehicles with heated and cooled seats, a Pelletier device is used for temperature regulation. To put it simply, this device uses electricity to make one side of an element hot and one side cold. When cooling, the byproduct hot air needs to be expelled, thus the vent. When heating, it just changes direction of current flow through the element and then expels the hot air air towards the occupant. These are pretty common on luxury cars these days, often used for seats, cupholders, refrigerated compartments. There are other methods for all of these things of course, but the Pelletier is a great option and a lot simpler than many other options.
Old Feb 18, 2023 | 06:30 AM
  #23
Defender90NY's Avatar
if one only has the heated seat option, maybe just a software configuration change will enable the cooled seat option? Sounds like the hardware is there already.
Old Feb 18, 2023 | 07:43 AM
  #24
I'm guessing non-cooled, heat-only seats use a heating pad rather than a Pelletier. But if I'm wrong, then you may be correct.
Old Feb 18, 2023 | 11:30 AM
  #25
X-dynamic's Avatar
Hi
Thank you, for the response, and the explanation of the system.
My issue is that cold air is expelled when the heated seats are on. This is why I'm thinking there is something wrong with the set up.
Best
Old Feb 18, 2023 | 06:45 PM
  #26
Originally Posted by X-dynamic
Hi
Best
Correct. The system reverses direction. So when cooled, warm comes out the vent. When heated, cool comes out the vent. Normal.
Old Mar 8, 2025 | 08:44 AM
  #27
ckamps's Avatar
On a related topic, in our 2022 D110 with front heated/cooled seats, we’ve been experiencing intermittent issues with the heating function. At times, when in heating mode, the seats will switch to cooling and not revert to heating until we stop the vehicle and let it sit for a while. We have not yet determined a pattern other than the heating function appears to work when first using the vehicle after it has sat for a few hours. On longer multi-hour trips, the heating function in either seat just stops working and we feel cool air,
Dealer made a first attempt to fix via an HVAC module software update but the problem persists.
More details are available at: https://www.defender2.net/forum/post...1.html#1062371
Old Mar 10, 2025 | 10:36 PM
  #28
nashvegas's Avatar
That’s a weird one @ckamps . I’ve got the headed/cooled “climate” seats and they work as they should. Def seems something is amiss.
Maddog84
Nov 6, 2020 06:03 AM
TVO
Jan 13, 2020 07:20 PM
mx468
Feb 11, 2016 09:48 PM
pathfinderheli
Jan 17, 2016 04:46 PM
jmt
Dec 28, 2007 03:22 PM
