Tracking Defender issues
#111
Have the sticky rear driver side door. The gasket at the top is too large so it catches the glass panel behind the door.
It's a really simple fix, just needs a new gasket.
If it's ignored, it can eventually break the rivets on the door frame where it's held on. The glass panel on the rear door can then come off. In other words, don't delay.
#113
‘My wife bought our 130, which I really like, especially on SW CO jeep trails. But for cross-country trips, which are frequent, it’s a debate on taking the 130 or my Ford F450 Kings Ranch which has massage seats with heat/AC. My old bones need special attention….🥴
#114
Well, this is new. Multiple error messages popped up out of nowhere including:
-Emergency Braking not available
-Lane Assistance not available
-Stability Control not available
-Terrain Response not available
- and the check engine light
I disconnected the battery which cleared everything, but the next day they all came back.
Seems to run fine, but the brakes are mushy, and that red BRAKE light is concerning.
I’m out on a ski trip - the one time you really need all the fancy computer stuff. At least the center and rear auto-lockers are working fine.
#115
#116
I checked for leaks - all looks good and the reservoir is full.
I’ll have the dealer sort it out - assuming nothing bad happens in the next 5 days of ski trip.
#117
Hoping not, but I would prepare for the dealer trying to link the error codes to the caliper swap and grind in an attempt to deny warranty service. Some dealers are worse than others though and maybe you have a good one.
#118
Yea, I’m prepared for that. If they give me a hard time I’ll just take it back to the independent shop that did the original installation. They still may charge for it, but it will be much less than the dealer.
#119
Here's my first real issue... received an "unable to select height warning" and a "height limited to normal mode". Have since been welcomed with a "suspension fault detected ok to drive" and the suspension buttons and terrain select disabled shortly after powering on.
I did hit a pretty nasty drop in pavement that was obstructed from view due to flooding the day before the warnings started.
Ran the codes and found C1A27-15 "Compressor Circuit - Circuit Short To Battery Or Open" fuses are good, the connection to the ride height sensors are good, as well as the looms around the fenders. Still need to check the relays, and the connection to the chassis control module wich i think is on the same side as the impact.
No popping or hissing or other audible clues from the compressor/ bags so thats a plus.
Front passenger sensor (area) maybe the root of this as that side took the brunt if the force.
