Trailer camera
Old Nov 3, 2025 | 06:14 PM
RH5555's Avatar
Lightbulb Trailer camera
Does any bright person know if I can re-purpose my Clearsight camera to allow me to mount a camera at the back of my travel trailer. Vague concept is to run an extension cable from the Clearsight fin to a compatible camera mounted at the back of the trailer, or possibly to relocate the camera in the Clearsight fin to the trailer. Any ideas?
Old Nov 9, 2025 | 01:52 PM
Sir Lands-a-lot's Avatar
I bought mine second hand and it had a trailer camera system fitted. However, I am only left with the cables, one between windscreen and HUD and then the connector next to an additional power supply for trailer/caravan with no idea what cameras were in use.
Using the clearsight system, you cannot add another camera for trailer (display issues on screen comes to mind) or even if you use just the one then mounted on trailer, you will likely get errors once the trailer is not in use. It would be far less costly just installing an independent camera. And unlike what I inherited, if I were to go down that path, I would look at a wireless solution with power hooked to trailer lights' power source.
Kajtek1
Nov 15, 2024 10:38 AM
TheManMac
Aug 26, 2024 10:16 AM
rbjewell
Jul 21, 2023 06:05 AM
airrage
Feb 26, 2021 06:42 AM
The DareDevil
Sep 24, 2018 03:03 PM
