Two way radio/antenna installations
Old Oct 27, 2021 | 10:17 AM
bobbo28's Avatar
Default Two way radio/antenna installations
Before I install my radio I'd love to see what type of equipment people are using and where they are mounting their base units and how they are installing their antennas. The radio I have (Midland MXT275 ) has an integrated control mic so I don't necessarily need access to the base unit. I'm also curious how people are running the cable for their antennas and if they are leaving the antennas on their trucks full time or removing when not in use.
Appreciate the feedback!
Old Oct 27, 2021 | 10:56 AM
umbertob's Avatar
https://landroverforums.com/forum/20...lation-106398/
Old Oct 27, 2021 | 11:18 AM
bobbo28's Avatar
Really nice install... thank you!
Old Oct 28, 2021 | 05:05 AM
Ludders54's Avatar
Hi Bobbo, I didn’t want to go drilling etc so I fitted the Thunderpole 3000 (short body) CB into an additional cubby tray - it’s easy to remove when not needed, the power goes down the side of the centre console frame into the cigar lighter in the rear (I hate having wires on show) and the aerial lead goes down the console, under the rear foot mats and up the side of the door seals to the roof. Found a chap in the UK who fabricated the metal bracket that fits the roof rails perfectly 👌🏼
Thunderpole 3000 short body CB Radio
Fabricated CB Aerial bracket fits into roof rail.
Old Oct 28, 2021 | 01:26 PM
Dan Hairy's Avatar
If you don't mind me asking where did you get those mounts that you are using to mount your microphone on Ludders54?
Old Oct 28, 2021 | 03:00 PM
Ludders54's Avatar
No trouble at all Dan. It’s from Brodit and fits on the dash crossmember or the centre console…..they sell them worldwide.
https://www.brodit.co.uk/brodit/vehi...021/655657.htm
Old Oct 28, 2021 | 03:14 PM
Dan Hairy's Avatar
Brilliant, thank you, mine is going to be for a mic mount also, I've just fitted the Midland M5 which also has all the controls on the mic and I have mounted the 'box' to the underside of the centre console
Old Oct 29, 2021 | 03:02 AM
Ludders54's Avatar
That’s easier Dan 👍🏼 I just boned the mic clip to the Brodit mount and can move it from the dash to the centre console. 👌🏼
suntreemcanic
Oct 10, 2021 07:26 AM
Dizzco II
Sep 7, 2016 08:09 AM
kpl1228
Aug 8, 2012 10:49 PM
yloDiscoII
Jul 15, 2011 11:04 AM
