4.6 engine build
Old Jan 6, 2015 | 08:17 AM
dusty1's Avatar
Originally Posted by duxd2
You said you are making shims. Will you need shims for these rockers? Aren't they adjustable?
They are adjustable
Just cutting some 22ga to make less adjustment. Also I have extra room in the covers, as I have to add a spacer there.
But no I don't "need" them
5/16 hd chrome molly push rods going in. head has to be bored/drilled to accept
Old Jan 6, 2015 | 08:21 AM
dusty1's Avatar
Originally Posted by drowssap
are those stock injectors or an upgrade?
Gotta get it completed first, then the calculating done by 5.0 for new custom. that will have to be one of the very last things....... of course I will probably end up producing a whopping 3 extra horsepower........in which case, I will save myself the embarrassment and just stick with these
Old Jan 6, 2015 | 11:02 AM
duxd2's Avatar
Originally Posted by dusty1
They are adjustable
Keep in mind that shimming the pedestals makes the rockers operate at more of an angle so the geometry changes which in turn affects the loads and wear points at the tips of the rockers, especially where the pushrods ride in the pockets. Probably not an issue with minor shimming and a mild cam but it's something to be aware of.
Old Jan 6, 2015 | 11:08 AM
dusty1's Avatar
yes I figured i'd have to play with it, to make sure I have the geom good.
Old Jan 19, 2015 | 02:47 AM
ls1morethanyou's Avatar
used grill oven cleaner to get of the thick gunk. elbow grease and a little $30 hf long shaft die grinder for the rest. yes i am painting everything white. not because i am fancy, but because i want to search and repair any leaks, before my engine becomes a big gooey mess. a case of vht white engine enamel.
drilling out the baffles a good idea? need to know for when i get back into town to do this as well.
Old Jan 20, 2015 | 06:26 AM
drowssap's Avatar
don't go too crazy on the paint LR used all that aluminum for a reason COOLING
Old Jan 29, 2015 | 11:35 AM
acg's Avatar
acg
Dusty,
Keep posting... I am enjoying the progress you are making... it will be great future reference for us.
Thanks!
Old Jan 29, 2015 | 12:22 PM
dusty1's Avatar
yes sir......my work travels have misplaced my fun time. just got in, from Atlanta, this morning. I will get back at it. excited to do so.
Old Feb 12, 2015 | 10:44 PM
dusty1's Avatar
more bits and pieces rolling in.
block, 1 head, crank, a couple of pistons.
block looks good, hats and new freeze plugs.
head looks good. the shop did a nice job fitting the bigger valves and springs. port and polish looks decent. a couple of places on the exhaust side, I will probably hit again (couple of little boogers, no big deal). so far so good. hopefully I will get some more boxes tomorrow.
off to find some friggin 3/8 bolts. I have every length in the world, except what I need to put this thing on the stand
Attached Thumbnails 4.6 engine build-dsc_3541.jpg   4.6 engine build-dsc_3540.jpg   4.6 engine build-dsc_3539.jpg   4.6 engine build-dsc_3537.jpg   4.6 engine build-dsc_3538.jpg
Old Feb 13, 2015 | 06:29 AM
drowssap's Avatar
it looks sweet all hot tanked and decked up, i assume you had the cam bearing done. what are you using for a rotating assembly?
